Old 01-18-2015, 04:09 PM
hondaxr hondaxr is offline
Default Snowthrower belt rubbing
I have a snowthrower on my Cub 127 and the BELT seems to be rubbing against tractor in PICTURE! Gear box mounting plate doesn't seem to have any SIDE TO SIDE movement to adjust! Wondering how can I adjust?
Old 01-18-2015, 04:22 PM
What model of snow thrower have you got mounted...???
Old 01-18-2015, 05:03 PM
Default Woops!
The Snowthrower model is QA-42! Thank You!
Old 01-18-2015, 05:41 PM
How about some pictures of the way this snow thrower is mounted. Side, front & top views would be helpful.
Old 01-18-2015, 05:46 PM
I'm going to go out on a limb here and say it's a QA42A.
My guess is it doesn't have the bushings on the shaft and the gearbox mounting has slid over to the side.
This should confirm.
Old 01-19-2015, 03:41 PM
Default More Pictures
Got some more Pics of front.
Old 01-19-2015, 04:03 PM
What would get get if you re-mounted the Gear Box and mounting plate (both) 180°.....????
Old 01-19-2015, 04:08 PM
It appears that your gear box is from a "QA 36/42 A", I'm guessing that the front mounting plate is too.
I don't have a QA 36/42 and a QA 36/42A here that I can set side by side to compare the differences but I'm guessing that this is where your problem lies.
Old 01-19-2015, 04:10 PM
I think the front mounting plate has a "lip" on the bottom edge preventing it from being turned over.
Old 01-19-2015, 04:27 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
That accommodates the belt tensioner pivot/anchor eyebolt.
Does not the pulley hole in the tractor plate dictate the outer plate orientation?
And also disallow mixing of plates from QA__ to QA__A if there is a difference?
What if the gearbox input pulley is different and bigger than original?
And how come O.P.'s 127 does not have the QA latch assembly?
