JD has a mid mounted pump.. Checkout WFM site and search tillers...
Torch and welder anything can be made!! |
![]() Quote:
The JD uses a pump that mounts under the tractor and has a belt that runs to the PTO. The oil tank is on the tiller. It holds 4.5 gallons from what I've read. I was just going to weld the mounts on the tiller and mount it on the 3pt.
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
plus you do have to remember that the case's, although perhaps arguably the most hydraulically capable tractors (oem) they also have their own oil cooler..so to run a case implement on another type would be an issue.. i think you would need to put some sort of cooler on it, or available on the tractor...even an old intercooler with a fan blowing across it would probably work...
Here is the cat 0 hydraulic Cub tiller. It is a model 190-004-100. I hear that they work awesome, will fit your cat 0 hitch and you can run the tines forward or reverse by the lever on the unit mounted spool valve(or whatever that handle do-hickey is). These are for the 3000 series tractors and use a shaft to turn the mid mount pump but you could mount the pump up under the front pto and use a short belt. I just missed one up in eastern Pa for $500. They hold 4 or 5 gallons of oil and it looks like they use the tiller shell as a heatsink.
I was looking hard for one of those until I found my 982(6) donor with all the goodies except PS....
They are hard to find but would do the trick if all you have is a sleeve or 3pt hitch. All self contained tiller.... |
Thread Tools | |
Display Modes | |
