Old 02-01-2015, 11:17 PM
Dadenstein Dadenstein is offline
kostendorf, I hope this helps https://www.youtube.com/watch?v=h_BwagaPO_w
Old 02-01-2015, 11:21 PM
kostendorf's Avatar
Your rockshaft is moving but the lift is not . the pin is broke.
Old 02-01-2015, 11:23 PM
Ok. Thank you. any suggestions of where to get one?
Old 02-01-2015, 11:37 PM
It's a spirol pin. Not to be confused with a spring pin. They are different. You can get them from CCC, IH, a parts store or "farm store" may have them. Order them online.... from Cub Cadet, McMaster Carr.... lots of places.
Old 02-01-2015, 11:40 PM
Hardware store, auto parts store, local Cub/Deere/etc. dealer, lawnmower repair shop, another garden tractor (but I would just buy new ones rather than used)..
Old 02-01-2015, 11:45 PM
kostendorf's Avatar
One of the sponsors at the top of the page or google it. Spirol Coil pin . they come in 1/4x 1 1/8" - 1/4x 1 1/4" - 1/4x 1 1/2" - 1/4x 2"
There has been a lot of post recently about how to get them out and replacing them.
Old 02-01-2015, 11:56 PM
I didn't watch your vid but if it's the pin on the outside of the frame that holds the triangle plate on it is a 5/16" spiral pin, you most likely won't find it at your local hardware store.
Check with out sponsors at the top of the page, or you can order a package of 5 or 10 from McMaster Carr.
Old 02-02-2015, 12:20 AM
Guys, I appreciate all the help. It is 11 here in Mi, and we are having the annual snowpocalapse. Seeing as to the fact that it needed an immediate fix, I stuck a 3/8x1" bolt in it and a couple of lock washers. should get one plowing in before I make it into town.
Old 02-02-2015, 12:58 AM
You'll shear it before you get anything done.... Sorry, but a bolt is just not strong enough....
Old 02-02-2015, 01:08 AM
Well then, its just gonna shear. I am Not getting back into that greasy tractor again until I have the part. Oh well. It was worth the try.
Tags
149, hydraulic lift
