Old 02-04-2015, 08:18 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Originally Posted by BassBlaster View Post
Could be. Im not sure. He gave me a piece he took off. It looks like it was probably a deck height indicator maybe. Anyhow, the bracket he fabbed up is now where that indicator is supposed to be and the plow linkage is connected to that bracket. I can probably get a pic of that. Give me a sec.
That's what should be there. Curious to see what's there.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-04-2015, 09:59 PM
Mcamp Mcamp is offline
did you check the oil level after you got home? running rich and smelling of fuel could be a crankcase full of gas.
Old 02-04-2015, 11:03 PM
BassBlaster BassBlaster is offline
No, I didn't. I checked the oil at his place and it looked good. Didn't check it again when I got home. It only ran long enough to get it off the trailer and into the garage. Ill check it again in the morning but I don't plan on starting it again until I figure out whats up with the carb. I do plan to change the oil and filter as well.
Old 02-05-2015, 03:29 PM
Upon further inspection in the daylight, I think Im just ignorant to how the plow blade works. I assumed it was raised and lowered from underneath like the deck. Now Im assuming it raises and lowers via the linkage that connects near the right floorboard. That would explain why the indicator has been removed and the home made bracket was one like the one linked from Ebay.
I also noticed the tires say Cub Cadet on them so Im assuming these were the tires that came on the tractor when it was new. New tires are gonna be a must. Im still taking suggestions. Seems turfs and ags are priced about the same. I suppose I don't really need ags as my yard is relatively flat and this will mainly be a mowing machine but Im sure it will be helpful for pushing snow. Again, all suggestions are welcome.
The battery purchase sticker says 1/08 so its definitely an old one. On my way to get a battery this afternoon.
Didn't get to tinker with the carb because its only 5 degrees out but I did notice the choke cable is junk and that may be part of the problem as well. Where can I get a new choke cable?
This thing is looking like it has enough minor issues that Im going to tear it down and clean it all up. Replace all the old fuel lines, etc. May even have a buddy straighten the fender pan up and put some new paint on it.
I took a few pics, Ill post them once they are uploaded to the computer. Thanks!
Old 02-05-2015, 03:40 PM
PaulF PaulF is offline
Cool, sounds like this tractor has promise, the most important thing is it seems to have an excited new owner
Looking forward to pics and future posts of your progress
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 02-05-2015, 04:03 PM
Yes, I am excited! Still a little bummed that its not ready to work but no big deal. Everything seems minor.
Heres a couple pics. One is the home made bracket we discussed earlier.
Old 02-05-2015, 04:16 PM
If someone could point me in the right direction to download a manual for the tractor and the deck, Id appreciate it. Its a 54" GT deck. I checked the technical area of the site but didn't see it. Maybe I overlooked it? Mainly looking for part numbers so I can cross reference. Thanks.
Old 02-05-2015, 05:20 PM
Send me a PM with your e-mail address and I'll send you the service manual for the Cyclops series tractors. Trust me a little work and a few $$$ will be well worth it for a god running 1864. Looks pretty good in the pics, congrats.
Old 02-05-2015, 06:24 PM
Sent you some stuff that should help. Enjoy.
Old 02-05-2015, 06:48 PM
Thanks a bunch. Gonna go study now!!
