#8741
That's a neat picture there Diz, your tractor is lighted up nicely
Paul F Infantry Veteran ![]() Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G |
#8742
Just a little clean up after the Blizzard that wasn't!
2082 w/60" Haban Deck & 450 Blower,AGs,weights 2084 w/54" Deck & 451 Blower 2086 w/54" Deck, 54" Haban Snow Blade 1864 w/54" Deck and weights 1641 w/48" Deck 1650 w/44" Deck parts Tractor (getting smaller all the time) 445 John Deere w/ model 40 FEL (went over to the dark side) |
#8743
Beats doing a clean up after the blizzard that was or could have been.
#8744
I came home from Daytona for this! My plane was the last one to land before they shut the airport. I did get some seat time on the CC, first outing for the 2082 with the blower attached, did a decent job once I got it dialed in.
#8745
I got the 782 out and put on my new step pads (Xtreme), SH drawbar (Jeff in PA), and spinner. Then just got a little mud on the tires!
![]() ![]() ![]() ![]() Some other presents showed up on the Brown truck the other day too! ![]() ![]() Friday I'm heading to Galax to pick up some other goodies!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
#8746
Power washed the new 128. Then painted the muffler and foot rest on the 125. With some time left I re-built the PTO. Will be ordering a bearing from Chris, that thing could not have worked in a long time! I am hoping the brown truck brings me some needed parts tomorrow.
CSXengr _______________________________ 124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart. |
#8747
Got to use the 3205 with hydraulic lift & BOTH wheel weights on today. Used a cpl times with only one weight & both chains. Made a noticeable difference. The diff lock helps too going uphill. If I had the motivation I'd also fill the rear tires with washer fluid. I'm liking that it takes 1/3 the time & engery than the power drive two stage blower. The plow makes quick work of it!
GT2186 & 3205 60",54" & 48" decks 2182SGT 60" w/ dual hydraulics-sold Craftsman GT 8 spd. 46"- stolen 11/5/14 JD L120 48", JD1025R, 60" auto, H120 fel '72 Murray GT B&S 16hp twin Dump trailers,Brinly,plow, disc, cultivator Box Scraper,spreader,Chains& weights front & rear Ford 841 & 851 powerMasters,6'Bushog,sickle bar Farm Pro 2425 6'disc,2btm plow,seeder/spreader, hay spears |
#8748
Diagnosed a failed ignition switch in the middle of the driveway, buried in snow. I guess I'll finish plowing when the mailman shows up.
Philip 1450, 1015, and a pile of parts. |
#8749
I got the 982 out and just had to let it enjoy some sunshine since it was abnormally 50 degrees this past weekend.
Cub Cadets: 582, 682, mini 5288 and 5488 Case International 235 compact Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank Living a dream one row at a time |
#8750
That is a cool looking 982 dirtcowboy
| Thread Tools | |
| Display Modes | |
