Old 01-27-2015, 02:36 AM
PaulF PaulF is offline
That's a neat picture there Diz, your tractor is lighted up nicely
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 01-27-2015, 03:29 PM
Group_44's Avatar
Group_44 Group_44 is offline
Just a little clean up after the Blizzard that wasn't!
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 01-27-2015, 05:35 PM
Beats doing a clean up after the blizzard that was or could have been.
Old 01-27-2015, 06:17 PM
Group_44's Avatar
I came home from Daytona for this! My plane was the last one to land before they shut the airport. I did get some seat time on the CC, first outing for the 2082 with the blower attached, did a decent job once I got it dialed in.
1641 w/48" Deck
Old 02-04-2015, 05:56 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I got the 782 out and put on my new step pads (Xtreme), SH drawbar (Jeff in PA), and spinner. Then just got a little mud on the tires!
Some other presents showed up on the Brown truck the other day too!
Friday I'm heading to Galax to pick up some other goodies!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-04-2015, 06:19 PM
CSXengr's Avatar
CSXengr CSXengr is offline
Power washed the new 128. Then painted the muffler and foot rest on the 125. With some time left I re-built the PTO. Will be ordering a bearing from Chris, that thing could not have worked in a long time! I am hoping the brown truck brings me some needed parts tomorrow.
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
Old 02-05-2015, 12:50 PM
Chetman's Avatar
Chetman Chetman is offline
Default Plowing snow with 3205
Got to use the 3205 with hydraulic lift & BOTH wheel weights on today. Used a cpl times with only one weight & both chains. Made a noticeable difference. The diff lock helps too going uphill. If I had the motivation I'd also fill the rear tires with washer fluid. I'm liking that it takes 1/3 the time & engery than the power drive two stage blower. The plow makes quick work of it!
GT2186 & 3205 60",54" & 48" decks
2182SGT 60" w/ dual hydraulics-sold
Craftsman GT 8 spd. 46"- stolen 11/5/14
JD L120 48", JD1025R, 60" auto, H120 fel
'72 Murray GT B&S 16hp twin
Dump trailers,Brinly,plow, disc, cultivator
Box Scraper,spreader,Chains& weights front & rear
Ford 841 & 851 powerMasters,6'Bushog,sickle bar
Farm Pro 2425 6'disc,2btm plow,seeder/spreader, hay spears
Old 02-05-2015, 06:16 PM
Nitro's Avatar
Nitro Nitro is offline
Diagnosed a failed ignition switch in the middle of the driveway, buried in snow. I guess I'll finish plowing when the mailman shows up.
Philip
1450, 1015, and a pile of parts.
Old 02-10-2015, 07:18 PM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
I got the 982 out and just had to let it enjoy some sunshine since it was abnormally 50 degrees this past weekend.
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 02-11-2015, 07:15 PM
That is a cool looking 982 dirtcowboy
