Glad that worked for you! Good luck tomorrow!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Do not do that. Quote:
![]() Quote:
Just what he said. The lift is for the 82 series. It's a floating lift, thus the slot. Works great on manual lift machines. There is a lock that can be bolted on, that's what the two little holes are for. Best option! My guess is, it's a rod for a 82 series. |
Interesting that my lift bracket looks different than any of the pics in this thread: http://www.onlycubcadets.net/forum/s...ad.php?t=23018
But since my bracket looks like it has new bolts holding it on, who knows where it came from. I'm guessing the "floating" slot will work just fine. I'll know for sure in the morning! I also have my snow chains ready to go, but I'm hoping it does just fine with just the Tru-power AG tires. Again, it's an experiment. Worse case is I head back to the garage if I spin too much and put them on.
1973 Cub Cadet 149 2023 John Deere X590 Farmall B sitting in relative's barn |
Cutting edge looks pretty skinny on both upper and lower like it's already been flipped once. Check the back side, I'd bet you are riding on the bolts already.
Screw the shoes down some, and lock 'em (are they even there?) they are there so the cutting edge don't wear so much. I'd take 'em down below the edge about 3/16- 1/4", so the edge don't leave rust marks all over the sidewalks come spring/summer. |
You guys were right on. The nuts on the wear strip are hitting the ground and have a small flat spot. It looks like the strip has not been used on the top side, so after this storm I'll flip it over and use new nuts. For now I adjusted the shoes so the blade is 1/16"-1/8" off the ground.
You should have some skids or "feet" that the blade should ride on as you are pushing snow to save the wear edge of the blade. I usually leave mine up about 1/2". I could not tell in your pictures if you have those on your blade or not, but you should. No harm in 1/2" or 1/4" of snow after your blade passes and it will save your edge. Do you have those skids on your blade?
I just checked a couple of junk ones that I had replaced. If the original cutting edge is nearing 1-1/2" they re pretty much done for.
1 blade I took in on trade was so far into the reinforcement behind the blade proper that it will require some serious restoration. The bolt holes were worn 1/2 way through. |
Skid shoes are nice for gravel.... on hard surface, they wear out as fast as the cutting edge. They cost about the same, if not more. |
| Thread Tools | |
| Display Modes | |
