Old 02-23-2015, 03:15 AM
Userj8670's Avatar
Default Warped heads
Seen a few posts where people have had a warped kohler head on their cubs. I had one myself that needed replaced last year on my k301. Was curious what causes this and can it be prevented?
Old 02-23-2015, 08:14 AM
The heads are aluminum. The heating up and cooling down causes them to warp. It can no more be prevented than you can prevent the piston rings from wearing out. There are things that help, like keeping the carb tuned so it isn't running lean (hot) and replacing the head gasket every 5 years or so..... but it can't be totally prevented.
By the way, they can be planed..... replacing them because they are warped is completely unnecessary.
Old 02-23-2015, 09:03 AM
I've only ever seen one warped head that was beyond repair, the engine had apparently ran so hot that the fins were deformed and laying over and when I put a straight edge on it I could stick an 1/8th inch drill bit between the head and the straight edge. That's an extreme case but as Jon mentioned don't run it lean and replace the head gasket every few years and it will minimize the warping.
Old 02-23-2015, 09:05 AM
boyesreef boyesreef is offline
always make sure you blow out your cooling fins after every mowing season as well. ive replaced engines on garden tractors all the way up to $30,000 Kubotas due to mowing chafe. when i got my 1450 cub it was fairly pack with chafe and mouse nest. i actually had to pull the air cleaner tube and pull a shopping bag worth out of the flywheel. then blew air in till it came out clean. THEN remove the muffler box and pull it out of there. i hate mieces to pieces.
Old 02-24-2015, 08:20 AM
charlie105's Avatar
charlie105 charlie105 is offline
Default cayenne pepper
I have found Cayenne pepper powder to be an effective temporary mouse repellant. Doesn't take much, but it does have to be reapplied if it gets damp. Makes the little buggers miserable. Just remember that it's there !
Old 02-24-2015, 12:17 PM
Userj8670's Avatar
Copy that! The dealer is who told me that it needed a new head when I brought it to them a few yrs ago for service. What's the best stuff to remove carbon these days?
Old 02-24-2015, 08:06 PM
cadzag72 cadzag72 is offline
I believe elbow grease is the best product
Ian
Old 02-25-2015, 03:00 PM
Userj8670's Avatar
I agree but I was thinking maybe some brake cleaner on a towel carefully rubbed on might help
Old 02-25-2015, 03:10 PM
red211's Avatar
red211 red211 is offline
I just pulled one off the new to me 128 this morning. I pulled the engine out to do the clutch, I was close so it hit the bench for a tin removal and blow job. Couldn't see any signs of head leaking and went back and forth but then popped it off. Was starting to leak so I guess that was a good move. Scraped with a wood shim, carefully with a thin paint scraper and very easy with a flat blade screwdriver in the tough spots. Kind of like a dentist reaching for that different torture device when the one he is using isn't tough enough! I used some brake clean after first scrape, then again rechecking progress. Dropped it off for a quick mill to make it nice and straight while I picked up a head gskt. Getting ready to put it back on after the block and piston are cleaned up.
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
Old 02-25-2015, 03:15 PM
For the deck, the best is a die grinder with these 3M pads on them:
For the head, I bead blast them. If you don't have a blaster, then the 3M pads for the gasket surface, and a wire wheel for the chamber. You can use brake cleaner yes, but it's kind of expensive for cleaning. I use mineral spirits, or even lacquer thinner for parts wash fluid. Let the head soak in it overnight and it will soften it up.
You could wipe it with a rag a brake cleaner all day and never get it all off. Gonna take a lot more than a rag!
