Old 03-03-2015, 10:56 PM
swacor swacor is offline
Default 1864
Hey everyone. I'm looking into a 1864 for sale. Comes with 54" deck and the tractor has 750 hours. I can maybe get it for $1,000. I've did quite a bit of research and found these tractors were one of the best built except for certain things (plastics and wiring). Any thing else I should look into. I have not looked at it yet but the pictures I saw seem descent. Thanks
Old 03-04-2015, 09:12 AM
Take a 9/16" wrench with you and check the bolts that hold the rear end in the tractor.
Old 03-04-2015, 01:23 PM
So if the bolts happen to be loose does that mean that something was damaged. Also can I put my qa-42 on there for now until I find the right 2 stage for it. Thanks
Old 03-04-2015, 01:32 PM
jimbob200521's Avatar
The QA42A will not work on an 1864 as it has the larger PTO up front.
-Ryan
Old 03-04-2015, 01:47 PM
I do have the smaller wider pulley on mine that will accept a 1/2 " or 5/8" belt.
Old 03-04-2015, 01:57 PM
PTO pulley is the wrong diameter, not belt size.
You could probably adapt the thrower to work..... but it's not "bolt on and go".
Old 03-04-2015, 03:21 PM
So if the bolts happen to be loose does that mean that something was damaged. Thanks
Maybe, maybe not, you'll have to check it over.
Old 03-04-2015, 06:02 PM
Dave01's Avatar
Dave01 Dave01 is offline
I have an 1864, mow with it all summer, love the machine. These have a very tight turning radius plus power steering that makes them great to mow with in places where you are mowing around trees, etc. Very rugged machine, Command 18 HP is an excellent engine with a long life.
If in good shape, and deck in good shape, $1,000 is still an excellent price for these tractors. All depends on how well they are maintained, and you should be able to see the answer to that when you take a look.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 03-06-2015, 11:05 AM
Just out of curiosity where's the best place you guys have found to get any parts on these 1864s. I've seen a few places and prices vary. Can I go to my nearest ag dealer that sells cub and get parts through them. Just looking into the future in case I get this cub. Any input appreciated. thanks again.
Old 03-06-2015, 11:11 AM
It depends on what it is that your looking for.
