#101
X's 2. I am also curious as I will be repainting the 70 soon
#102
The O is looking good. You do good work
Terry
#103
The Green cleans off the oil and grease, while the lacquer loosens up the paint. Then I wire wheel again, but with a medium wheel. Like on the housing, I clean the grease and crud with the Green, then I'll use a hand held wire wheel on a drill and a DA, where I can. I don't strip the paint where it's good, just feather it into the bare metal spots. Yes it was, thanks again Lew ![]() Thanks. Thank you.
#104
Had a idea today......and thought about making a battery hold down seeing they are N/A anymore.
Had some round stock around the shop. So I cut it to two feet in length and fired up the torch. Took a 3/8 bolt and bolted it to a board to make the round ends. Then welded the ends together in the middle. Pretty close to the original, except not rusted in two ![]() Turned out pretty good
#105
Very nice job Todd.
#106
Nice work Sir,when do they go into mass production?
#107
Nice work from the master.
#108
Put a new set of seals in today and got the trans ready for primer. Installed a new shifter gasket and the "IH" bolts.
Little by little, it's going together. Another six months should be a roller
#109
Todd,
That battery hold down bracket looks like factory. Tank and clean up work looks good too. Zinc plated bolts will pop against the yeller! Love it when projects start to go back together. Hope things are good! Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
#110
Did a little on the original today. Installed a new reduction housing gasket and housing. Got the break parts cleaned up.
Installed the right axle and tube. I made a couple axle housing guides out of 3/8 bolts with the head cut off to help me hold everything while I'm putting in the bolts.
| Thread Tools | |
| Display Modes | |
