Old 03-16-2015, 07:08 PM
elway elway is offline
Default My first real hydro tractor, My first post
I ran across this 1862 on CL, it was also on the Farm Equipment company's Webb site. "The tractor was a trade in, the owner passed away , It had been parked in a barn for years, They couldn't get it started" As is Where is $500.00. So I bought It. Hauled it home put a good battery in it (expecting to find it sized or knocking) it cranked and had good compression, but would not start. Took plugs out had spark, no gas to the carb, Somebody replaced the starter solenoid and fuel pump and crossed the lines, the out was connected to the crank case and the pulse was connected to the carb I changed the oil and filter (oil was like water) is started right up, all things seem to work (50" deck and mule not back on, They took off to move with fork lift)
It runs drives fine, its quiet. The transmission is low on fluid... What kind can I add for now. Until I can change it. The local TSC has "Cub Cadet® Drive System Fluid Plus" $14.99 QT Suggestions, Thanks
Old 03-16-2015, 07:21 PM
First, welcome to OCC...
Congratulations on your purchase.
The correct and recommended Hydro Fluid is HyTran. It is available from your Cub Cadet or Case/IH Dealer(s).
See Hydraulic Fluids........ Hydraulic Fluid
It is most economical if purchased by the Gallon at your local Case/IH dealer. The rear end takes 7 Qts.
Old 03-16-2015, 07:57 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Elway, welcome to the forum and congratulations on the 1862! I'm sure it will serve you well. This forum and the members on it, is a real treasure trove of information that can usually get you up and running with just about anything you run with your cub.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 03-16-2015, 08:43 PM
Tankman's Avatar
Tankman Tankman is offline
I'm a newbie here too Elway.
Great knowledge and better, experience here that forum members will be more than willing to share.
Please do keep us updated, I myself need to know. Heck, all want to know how you're makin' out!
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-16-2015, 09:26 PM
Welcome to the Cyclops club. Here are a few threads about what you now own.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Holler if I can be of assistance.
Old 03-25-2015, 02:16 PM
Can some one tell, Who makes the hydro pump in this tractor? Can't see a tag. sn/816321. Thanks
Old 03-25-2015, 03:25 PM
1862's had Sundstrand hydros.
