Old 03-24-2015, 10:14 PM
nebmatt nebmatt is offline
Default 125 Kohler 301A Carb Trouble
Recently had work done on my 125 and will not run to save my life. I read through my manuals and cleaned and made sure nothing was blocked everything is free. I have turned everything in out on turns as manual says will lug and that's it what am I doing wrong advice needed thanks.
Old 03-24-2015, 10:26 PM
Your post is a little vague, what did you have done, was it doing this before, did you make the afore mentioned repairs to eliminate this problem or for another reason?
Will it not run at all, or does it not run at all well?
Old 03-24-2015, 10:34 PM
I had the throttle shaft sleeved with a new bushing it ran perfect before an that was it. It will not run I made adjustments will not run at full throttle nor low ideal floods its self out or not enough gas throttle is operating as it should will run with starting fluid
Old 03-24-2015, 11:29 PM
If it were mine, I would most likely take it apart (again) soak the carb. overnight in carb. cleaner then blow out all of the passages with compressed air including the high speed needle, flush the tank and lines and clean/replace whatever type filter you have, check the float for saturation, put a new kit in the carb. and put it all back together again.
It's my guess that some crud in the system became dislodged and has caused a blockage in a crucial area of the system (more than likely between the fuel line fitting on the side of the carb. and the needle valve).
Old 03-25-2015, 07:35 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
make sure you adjust the governor to the carb
Old 03-25-2015, 09:38 PM
Great advice given already.....just wanted to add that you might check your adjustment screws. The main fuel jet should be set to 2 turns and the low idle jet should be set to 2 1/2 turns. Some adjustment might be made to these, but these are per Kohler manual.
http://www.kohlerengines.com/onlinec...df/tp_2379.pdf
Hope things work out for you,
Old 03-26-2015, 06:01 PM
Those settings are just a starting point.
Old 03-26-2015, 08:14 PM
That is why I mentioned "some adjustment might be made to these....", especially if he planed his head, change to run more rich/lean, etc.
Old 03-28-2015, 01:55 PM
Thanks for all the advice and what to look for I have not had time to work on it again till now hope to get it running today thanks
