Old 04-05-2015, 05:04 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Default Stupid 1250 question
On the air filter side of the 1250 engine. How many seals are there. I want to change the oil, and any seals that could be leaking once drained.. Oh, there is a leak from something, not sure where. main reason for the question..
I am broke, but I make it work!
Old 04-05-2015, 05:08 PM
If I could get finger pointing pics that would be great. this computer is not letting me see the manual.
Old 04-05-2015, 05:47 PM
If its leaking oil on the carb side of the engine the 2 most likely causes are the cam cover or the breather.
Old 04-05-2015, 08:27 PM
Or the brass nut that holds the governor shaft,where do you see oil now?
Old 04-05-2015, 08:45 PM
It is kinda smeared if you will, all over the side. it is not puddaling anywhere.
I really cant find a source. Kinda why I am asking. Now I am not really sure what the box 1 oclock to the point box is. but it seems to be heaver around that.
Old 04-05-2015, 08:47 PM
That's the breather right under the carb. The vertical cover is the cam cover. If you have a lot of blow by or those components installed incorrectly (breather) or bad gasket it will leak
