Old 04-11-2015, 12:59 PM
Tomstadler88 Tomstadler88 is offline
Your situation will most likely be, the Spirol Pin failure or a plugged Hydro Filter. Either will cause a lack of fluid to travel throughout the Sundstrand Hydraulic Unit.
ok so here's an update; changed the fluid and the filter.... nothing. spirol pin(s) are intact and the pump has power. pulled the plate off the differential, looks good. pulled the valves (at least i think they are valves) off the top of the pump as i hear these can get gunked up but they are spotless.
still no power to rear diff.
what's next?
Old 04-11-2015, 01:02 PM
Go to this link. Down load the Service Manual. Look at page 2-93 and perform the Charge Pump Pressure test. Tell us what you find..... Service Manual
Old 04-11-2015, 03:16 PM
- pressure test yielded about 95 psi @ idle
Old 04-12-2015, 12:27 AM
Even at 95 PSI it should work. More than likely the charge relief valves (the big ones that you are holding in the pics) are stuck. Could be a charge pump issue, but more likely the valves.
Did you try moving the lever with the gauge installed? If so, what did it read then?
Old 04-12-2015, 01:42 PM
The pressure would drop to about 70 psi or so with the lever engaged and would be 'jumping'
I'm starting to think this is a charge relief valve problem... Are the ball bearings in the valve supposed to be freed up? They were rock solid. How can I diagnose a bad valve problem?
Old 04-12-2015, 02:18 PM
YES, there is to be "free travel" of that steel ball inside the valve.
There is your problem. You have three choices:
(A) Soak the valve(s) in a solution (ie: PB Blaster) and get the steel ball to travel freely.
(B) Send the valves into someone for rebuild.
(C) Buy new valves.
Old 04-13-2015, 12:10 AM
johns cubs's Avatar
johns cubs johns cubs is offline
Try soaking in kerosene, or some brake fluid should do it.
John
Old 04-13-2015, 12:42 AM
Brake fluid? Explain that one....
Old 04-13-2015, 12:27 PM
Yup I think we're on to something... I will play around with it this afternoon and update after. Fingers crossed! I don't want to buy new ones that's for sure
Old 04-13-2015, 08:41 PM
Good news everyone!!
Soaked those suckers in some PB blaster and gave them a few taps in the floor- good as new. Installed them and the thing runs great. Thanks to everyone who helped me out on this one. Glad to give this buggy a second chance. Great first experience on the forum!
Ill post some pics tomorrow
Tags
1250, cub cadet 1250, hydrostatic, transmission
