Alright fellas, I need a swift boot in the right direction here. First off, I'd like to thank all you guys for all your knowledge and help already. I inherited my Father in Law's 2082 Super last summer for lawn mowing duty at my newly acquired home. Towards the end of summer last year the bearing froze up in the PTO and I didn't have time between work and home renovations to tear things down and replace the bearing so I just finished the season off and parked it.
Fast forward to this week, I pulled the PTO apart, pressed out the old bearing, picked one up locally and pressed the new one back in. Now I'm sitting here on a bucket in the garage trying to get this thing adjusted so it works correctly and can't for the life of me get it to work right. I've got my feeler gauges, I'm setting the air gap to .015" like I saw in one of the other "PTO Woes" thread but I'm confused at what to tighten first. When I tighten the (3) 9/16" nuts that hold the pulley assembly and set the air gap, as soon as I tighten the 5/8" bolt on the front of the pulley my air gap disappears and the PTO remains engaged all the time. If I leave that 5/8" bolt loose so the pulley spins free and maintains a .015" gap at the three places to check then when I fire it up after it runs for a few seconds the bolt tightens up and the PTO engages even though the switch is off. Which do I tighten first, 9/16" nuts or the 5/8" pulley bolt?? When I run the 9/16" nuts in first, it seems like that doesn't mess with my air gap? Am I not running them in far enough? And I'll throw up a picture of where I'm checking the air gaps, just to verify I'm checking in the right spot. Thanks guys!
Looking at your pic it looks like the bearing is not pressed into the pulley as far as it should be. The 5/8" bolt that holds it on the crank shaft should be tight. The 9/16" nuts circled it red are what you tighten to adjust the air gap, make sure you do all 3 evenly. Thread on how to adjust the air gap.
http://www.onlycubcadets.net/forum/showthread.php?t=30
I was beginning to wonder that after I posted this. I'll see if I can't press it down in there some more. Thanks Sam!
Pressed the bearing in further, put it together and everything works fine. Thanks again Sam! Now, any links to help a guy put a new starter in this thing. It looks like quite the project.
If I was going to do a starter on that engine I'd pull it out to get at it. If you haven't downloaded the service manual I suggest that you do, it's in our tech library.
Link to the manual. http://www.onlycubcadets.net/forum/s...ad.php?t=25397
| Thread Tools | |
| Display Modes | |
