#21
![]() Quote:
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#22
Todd,
Catching up with you. I agree the tractor doesn't look too bad. Hope you can solve some of the issues easily. I guess if you buy enough of these a, bad one may be in the mix somewhere. Don't be to hard on your self. Imagine if this guy sold it to someone who new nothing about them. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
#23
![]() Quote:
Been working on it off and on the last few days, maybe a diamond in a goats butt...could only hope. ![]()
#24
Haven't given up yet, and actually things are looking better all the time. I got the rear seal, that actually is in the front replaced. Got the two bolts replaced that I broke off on the field coil, and put on new valve cover gaskets. So now the oil leaks are gone, and the PTO works as it should.
![]() Pulled the carb and gave it a cleaning, and now the damn thing seems to run pretty good. Changed the engine oil and filter, installed a new fuel filter, and fuel line. I have the tunnel cover off and noticed the lip seal on the front of the hydro is leaking so I ordered a new one today. Should be in by the end of the week, then I'm going to change the HY-TRAN and filter and go from there. I'm really digging this tractor, and don't want to give up on it yet and punt it down the road. The more I get into it, the more potential I see ![]() I'll throw in some pictures tomorrow, "looks" way better already ![]()
#25
Glad to see you "digging in"
![]() Now, where's the pics? ![]() Did you check for corrosion at the plug in the wire? Common problem and will cause a misfire. ![]() |
#26
![]() Quote:
![]() Here's the pictures. Overload ![]()
#27
Lookin good Todd. Just my 2 cents, it's pretty easy to pull the engine out of the frame on those. Remove the 6 3/8" bolts under the frame along with the wiring, cables, hoses and unbolt the drive shaft and hook it to your hoist. This one had a mouse condo in it.
#28
Even your dog has Cadet Fever.
Lookin' good. |
#29
![]() Quote:
#30
I just find it easier to get at the starter and clean it up good. If yours is clean no need to do it. Just trying to help.
Thread Tools | |
Display Modes | |
