Old 04-25-2015, 09:39 AM
I read on another forum that there was a tool to make the ends you are talking about...let me see if I can find that.
What do you guys think about silver soldering a small round washer onto the proper size brake tubing to make the fitting?
Old 04-25-2015, 10:29 AM
gt383mag's Avatar
gt383mag gt383mag is offline
Originally Posted by Datsun1973 View Post
You could use the ends from a set of lines and flare the other side to accept a tube nut effectively making your own lines or adapter to standard stuff. Being a race car guy I am sure you have the 45 flare tool and a box of AN fittings. Hehe
i attempted this the tube is very thick my flare tool strugles with the stuff you buy in a auto parts store and this stuff is quite a bit thicker
Old 04-25-2015, 10:35 AM
gt383mag's Avatar
group44 ican think of three options 1. tap to 9/16 18 and use ORB fittings 2. tig or braze a fitting to your line 3. use a compression fitting ( my brother has used them on two tractors with no problems yet )
i think the brazing thing is the way to go as the lines will be allready pointing the rite way
Old 04-25-2015, 11:32 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
that's a freaking HVAC guy for you
Old 04-25-2015, 11:55 AM
Yep, I can't weld for crap but I silver solder just about anything.
Old 04-25-2015, 01:25 PM
Datsun1973 Datsun1973 is offline
Yeah the auto parts store Chinese flare tool won't work. I have one for doing 45 flares in stainless lines for my GT2 race car. I also flared a bunch of hard lines for the oil and cooling systems. Again, all stainless. I think I got it at Pegasus Racing supplies. Not cheap but it has paid for itself a few times.
Old 04-25-2015, 04:12 PM
Group_44's Avatar
Group_44 Group_44 is offline
http://www.mastercool.com/pages/flaring_tools.html
I think this is the tool you are talking about. It's a bit pricey but I may bite the bullet since it will do just about every flare you can imagine. The particular flare that closely resembles the CC style is for GM push on fuel line connections. I am in the process of trying a repair line I found in the help section of Advance Auto to see if it will work in the valve.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 04-25-2015, 04:22 PM
I have that tool. It will make the fitting.
Old 04-25-2015, 06:33 PM
Group_44's Avatar
Does it give you a big enough edge for the clamp to hold securely? I have a piece of GM fuel line with that type of flare and it doesn't seem as wide as the CC fitting, real close though.
1641 w/48" Deck
Old 04-25-2015, 07:37 PM
gdheck's Avatar
gdheck gdheck is offline
If it won't make the flange large enough, I bet a die set could be modified so it makes the correct end. I thought about doing that with my Mastercool flaring tool, but after you make the fitting you'll still need to make a bend tight enough to fit under the side panel. That might be the hard part unless someone has found a tight radius bender that I haven't found yet.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
