Old 02-04-2015, 05:18 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Originally Posted by DoubleO7 View Post
LOL, think about the wording.
Sorry, my brain ain't working too good today.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-05-2015, 10:23 AM
cubfan's Avatar
cubfan cubfan is offline
Well I guess quiet a few of us are geniuses cause I for one have put WWF in 8 different 26×12×12's with tubes in them.I think I managed to get 11 gals in 4 of them and about 10gals in the other 4.Difference being the wheels.I just use a pressurized pump up sprayer.Works grrrrreat.
Old 03-07-2015, 07:30 PM
vargafarm vargafarm is offline
I've pulled fluid out of a 15.5 38 using a 12 volt sprayer pump.
Transferred it from a tire with a bad rim into a good tire, took out the valve cores and used hose clamps to connect the two.
Had to stop a few times to let the air out as the fluid filled it.
Old 04-26-2015, 11:47 AM
Woodbutcher Woodbutcher is offline
Has anyone tried buckshot?
Old 04-26-2015, 04:47 PM
Sam Mac Sam Mac is online now
My guess is it would work but probably very expensive.
Old 04-26-2015, 05:17 PM
o---o o---o is offline
So I need about 9 gallons for a Tru Power 23 10.50?
Old 04-26-2015, 06:41 PM
Shrewcub's Avatar
Probably 7-8.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-26-2015, 07:37 PM
Probably 7-8.
Thanks, I want to buy enough but not too much.
Old 04-26-2015, 08:49 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Might look into recycled shot.
It is available online.
Or get in touch with your local shooting range.
Old 03-18-2016, 09:43 PM
micahw micahw is offline
Default tip
I keep a 2 liter soda bottle, drill a hole in cap and bottom that fits a valve stem. take core out of bottom stem and clamp a piece of hose to it. you can even put a shutoff valve in the hose if you want. fill the bottle with fluid attach hose to wheel stem and pressurize the bottle with air , and it will push fluid out the bottom. This works great for gear oil in the winter too, esp for those hard to get to gearboxes. Have also used it to test junk cars with no fuel pump as you can regulate line pressure to simulate fuel pump.
Tags
tires, weights
