My mule drive never came with the tension release handle. I've been running fine without it by making it common sense tight, but for fun I thought I would look up the spec for tensioning. The manual states 3-1/2" between the pulley bolt and mule drive on 38" decks with a coil spring tensioner. It says to use the notches in the tension arm for 44" and 50" decks. Can I use the same 3-1/2" spec for the torsion spring tensioner? Does someone have a tensioner arm lying around they can measure the notches and cut out for me so I can make one?
Thanks Bill |
As long as your pulley's are even with each other it should be fine, till you get
the part you need. |
My 1200 with 44A deck just has a J- bolt for adjustment. Never had the tension release handle.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
| Thread Tools | |
| Display Modes | |
