Old 05-06-2015, 02:11 PM
breed-102 breed-102 is offline
Default 102 shifting help?
So I have a 102 and sorry for sounding stupid but this isn't really a knowledgable area for me; it doesn't like to go into gear. I will fully press in the clutch but the shifter will not go into any gears. This only happens occasionally but I just want to know what it is and if it is going to get worse.
Thanks and again sorry that sounded stupid!
Old 05-06-2015, 02:34 PM
rbarri2's Avatar
rbarri2 rbarri2 is offline
have you checked the clutch adjustment and transmission fluid level?
It's not gonna get any better........
PLEASE CONTACT ME BY CLICKING MY USER NAME ABOVE.
1968 Cub Cadet 124 with deck and #2 Trailer
1965 IH Scout 80 Champagne Edition
1968 IH Travelall 4x4 and factory PTO winch
1955 IH Refrigerator
Old 05-06-2015, 02:45 PM
It really depends on what is wrong, there are any number of things it could be.
Not to worry about sounding stupid, I sound that way all the time and it doesn't bother me a bit.
Everyone can't know everything about everything, if you've never messed with something like this how would you know???
You don't mention anything about grinding the gears, when it doesn't want to go in gear does it grind?
I guess the first real thing to check for is, when this happens, check to see if the drive shaft is still spinning (along with the engine) when you push the pedal down.
When this happens, what do you do to get past the problem?
I think the answers to these questions can give us a better idea of what we're looking at.
Old 05-06-2015, 05:58 PM
No it doesn't grind, it just won't move into gear. I will check if the driveshaft keeps spinning as soon as I can and get back.
Thanks
Old 05-06-2015, 07:17 PM
Tim.E's Avatar
Tim.E Tim.E is offline
The gears in the transmission are straight cut,,,,,, the teeth must be aligned in order to mesh with each other. try this,,,,,,depress the clutch pedal down far enough to disengage the clutch but not far enough to engage the brake, then wiggle yourself in order to move the tractor forward or backward an inch or so,hopefully this will line up the teeth on the gears and allow them to mesh.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 05-06-2015, 08:08 PM
cadzag72 cadzag72 is offline
I have this happen to me sometimes with gear drive Cubs and larger tractors too, I usually let the clutch up ever so slightly to get the drive shaft to spin just a little bit, then just before it stops spinning, gently try putting it in the gear I want. Doing this you can "feel" your way into a gear. I must emphasize doing this GENTLY, do not try jamming it into gear or you will damage the gear teeth.
Ian
Old 05-06-2015, 10:30 PM
First off I just want to say thanks for the responses to my issue! I took off the cover off of the back and this is what I could see. (Again I am a noob) how would I check the fluid levels in the tranny? FYI the pic is sideways
Braden
Old 05-06-2015, 10:42 PM
Welcome to OCC!
Here is a link to the operators manual for your machine. It should answer most of you "noob" questions.
http://www.onlycubcadets.net/forum/s...ead.php?t=4662
If you have more in-depth questions, here is the chassis service manual.
http://www.onlycubcadets.net/forum/s...ead.php?t=4641
Old 05-07-2015, 09:30 AM
I do agree that you should familiarize yourself with the manuals, but to keep you from farting around for a week looking for the answer to one question in the manual.
Fill the rear end through the hole (with the plug) in the rear cover, when the fluid runs out, the trans-axle is full.
The book also say to use IH-Hy-Tran Fluid or SAE 30 engine oil.
Old 05-07-2015, 12:58 PM
Ok cool, I'll give that a try, and what Tim E. and cadzag72 said. Thanks a lot guys!
Cub Cadet 102
