Have a IH 129, the weekly workhorse, that I was using to mow. I ran over a bit of a tree root, a somewhat significant bump, and the engine just died. The engine still turns over but just won't start. Was thinking maybe a safety switch but the switch to engage the blades seems to be working just fine. There is no spark but that might make sense. Any thoughts on how to begin to troubleshoot this? Any general direction would be greatly appreciated. Thanks in advance.
Newbie Rob |
Switch to engage the blades? 129 has mechanical Pto. Do you have a later engine transplant in this? You need positive battery volts to positive side of coil during start and run. Negative side will flash test light during start, doyou have that?
Sorry. The brake pedal that engages a switch behind the gas tank ( won't start without your foot on the brake ) and your absolutely right about the pto for the blades.
First, welcome to OCC.
Sounds like an electrical issue. Click on this link for the Wiring Diagram..... 129 With the Key in the On position, do you have 12V from engine block ground to the (+) of the Ignition Coil...???
Actually, they do have a pto safety switch on the driver's right side as well as the foot pedal safety switch, but I doubt that it went out. You do need to pull back on the deck engagement handle to enable that safety switch! Have you pulled back on it and tried starting?
Using your 12V test light attach the clip to ground, turn the key on and touch the pointed end to the pos side of the coil. It should light up. Turn the key and make the engine turn, it (the test light) should stay on.
Clip on ground, touch pointed end to neg side of coil, turn key to make engine turn. Light should go on and off while engine is turning. If these requirements are not met, your engine will not run and there is no need to look any further.
So I don't have a light but just used a multimeter
Key on- Ground to (+) side of coil= 12v Key on- Ground to (-) side of coil = 0v Key on to start - Ground to (+) side of coil= 12v Key on to start - Ground to (-) side of coil = 0v Does this tell me it's the coil then? Thanks for all your help. Rob |
Did you try to clean or replace the points?
![]() That's the most common ignition issue i have with old engines Sounds to me like the coil is fine On the tests that you got 0v you should have done. Ignition on, one wire from meter to negative on coil and other wire to positive on battery. You should get 12v then. If you wanted to test ohms you could do negative on coil to ground
1961 Original 1962 original w/ fenders and creeper 102 72 w/ fenders and lights 124 w/ sleeve hitch 129 w/ lights 5 mower decks, 2 plow blades, 1snowblower ![]() ![]() ![]()
Test your Ignition Coil per this....... Test
Step #4 - What you see will be some positive voltage less than 12V because the voltage is pulsating as the points open and close and the meter can't fluctuate fast enough. A test light would flash on/off at the speed the points open/close. Steps #1 & 2 - As long as the key is in the on or start position you should always have 12V on the coil positive pole. Off position always 0V. Incorrect indications on the coil negative pole can be caused by points that are pitted, dirty, shorted, not set correctly, etc. Also your condenser is attached to the negative pole of the coil and to ground on your engine housing. The condenser is a capacitor and is electrically bridged across the points to reduce arcing on the points. If the condenser shorts out it is the same as your points never opening and you will always see 0V on the coil negative pole. On the other hand the condenser can burn out and this will shorten the life of your points. Test lights are cheap & helpful, pick one up. |
| Thread Tools | |
| Display Modes | |
