Old 05-16-2015, 01:05 PM
PaulS's Avatar
PaulS PaulS is offline
Default Wire Size
I have to rewire the headlights on my 2084 and am clueless on what gauge wire to use. I have some 18 gauge from a heavy duty drag cord that seems to have good flexibility and a decent covering. My present wires covering has become brittle and even broken in several places. I have to wire up my new headlights that came with my new nose piece and grill as they are sealed beams instead of the plug in bulbs that are original. It seems to be a good time to rewire.
Old 05-16-2015, 01:19 PM
Rguyer04 Rguyer04 is offline
As long as you are only doing your lights 18 will be fine. If you look at a car most of the wires in them are 18 or smaller most times.
1862, 400 tiller, brinly 10'' plow
1282
Old 05-16-2015, 10:47 PM
fourinchdragslicks fourinchdragslicks is offline
I assume you have 35W sealed beams, that is around 5 amps. You are perfectly safe with 18 ga. (although I prefer to wire heavy) I am not sure what a drag cord is, I have never heard of that term. If you have a concern over a long life for the wire, check what the temp rating is on the wire, or wrap the wire with some sleeving to shield it.
Old 05-17-2015, 10:02 AM
darryljs's Avatar
darryljs darryljs is offline
DRAG CORD = extension cord.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 05-17-2015, 10:06 AM
I never heard it labeled like that either.
Old 05-17-2015, 10:12 AM
darryljs's Avatar
Maybe it's a PA thing.
Old 05-17-2015, 05:52 PM
Haha, I even googled it before I responded. If it is a GOOD extension cord it should be pretty flexible, and even have the temp rating of the wire on it. That said, I cant remember seeing a GOOD extension cord that was 18 ga, but I hate to by smaller than a 12 ga (it never fails, I need a heavier cord than a 14 ga)
Old 05-17-2015, 09:35 PM
PaulS's Avatar
Ha Ha drag cord is what we have always called it. Yes it was part of an extension cord. I wired up the lights this afternoon and must say so myself I copied what I cut off the original headlight setup. I did find that the original wires were heated so many times over the years that the rubber coating was brittle for about a foot down from the headlights so I spliced the new wires at that point and proceeded to further splice into those wires for the other headlight. Hooked up the wires and had lights. Oh and we call an extension light a drag light too.
Old 05-17-2015, 10:36 PM
not in my part of PA.
Old 05-17-2015, 11:51 PM
cnsolutions cnsolutions is offline
I second that I never heard that term before. I'm 60 miles north of Pittsburgh.
Cub Cadet 2284
Bobcat S220
Allmand TLB225
IHI 35NX2 Excavator
Ford 661 5 Speed Double Clutch
