Old 05-28-2015, 09:26 PM
Wbrech Wbrech is offline
Default Tach help
What tach are you guys using as a "tech" tach. Need something for checking RPM's in a governed class. We have a tach from echo that everyone says is the one to have. It reads accurately on my rototiller but put it on the cub and it reads 900-1700 at idle and bounces from 3200-5000 wot. Is there a timing light with a tach on it that will work with a single cylinder?
Old 05-28-2015, 09:48 PM
125 cubowner's Avatar
125 cubowner 125 cubowner is offline
we are using a tach from Equus it is 8068 and it has inductive or coil wire hookup hope this helps
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
Old 05-28-2015, 09:51 PM
I use a mechanical RPM meter.
http://www.onlycubcadets.net/forum/a...1&d=1423451332
Old 05-29-2015, 11:19 AM
bschmittling bschmittling is offline
http://www.egauges.com/8K-RPM-Tach-2-1-16-p/333-968.htm
This will work.
Old 05-29-2015, 07:31 PM
Thanks guys.
Old 05-30-2015, 07:47 AM
Bought an Actron CP7529 seems to work good.
Old 05-30-2015, 07:52 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
vibratach from Briggs and Stratton.
Old 06-04-2015, 05:58 PM
http://www.amazon.com/0-9999RPM-Univ...6H0M5RNZFKJW2A
Here is one I found for $12. Reviews are not great but it looks like people had trouble wiring it and it ships from China. For $12, I'll give it a go.
Old 06-04-2015, 08:30 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Originally Posted by 64fleetside View Post
Stewart-Warner also made a vibration tachometer. Works on the same principle as the Vibra-Tach that member dvogtvpe mentioned.
Plow blade
#2 Cart
QA36 snowthower
