I've finally begun tearing down my 100 to repaint and rewire it. The engine (K301) may get rebuilt as well since it smokes a little at startup and has a slight knock when under a moderate load. I already have a set of Maple-Hunter decals I bought about 5 yrs ago when I originally planned to paint it. It needs a new hood and there are a few extra holes in the tower that need welded shut. I don't plan for this to be as thorough, or time consuming, of a repaint as my red 129 since the 100 will retain the factory paint scheme.
On to the before and current progress pics. ![]() ![]() ![]()
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Let the fun begin.
![]() What brand are those front tires?
They are Carlisle Field Trax. They discontinued the 16/6.5/8 size about the time I bought them.
Looking forward to watching your progress.
-Bob- 149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104 |
Got the engine pulled and started disassembly so that I can measure the bore and rod journal to see what piston and rod I'll need for the rebuild.
![]() ![]() There was quite a bit of carbon around the valves and spark plug which I expected since it was using about 6 oz of oil per hour of run time. The top of the piston and bottom of the head were covered in oil. ![]() ![]() ![]() The piston is definitely in need of replacement going by the wear near the exhaust valve. ![]() ![]() The ring end gap checks .070" which seams excessive.
she runnin a little lean at some point??... tractor is in really good shape though for its age... some one took care of it... glad to see her get treated right.. knowing your stuff, im sure its gonna be sweet...
My dad bought the tractor around 1980 and it's never sat outside since. Part of it has been repainted before because there is paint flaking off of the tower and the original paint underneath is in better shape.
Looked up the specs for the engine and the ring end gap is supposed to be .010"-.020" new and .030" max so it is definitely worn out.
I may not be rebuilding my K301 after all. A friend offered to sell me his 149 for a good price. He was told by a guy we work with that it was rebuilt with a Kohler piston and rod and only has about 50 hrs on it. He hasn't had it running though since the S/G is bad. I might take my S/G over to his house and see if I can get it running and buy it. Then, I'll either paint the engine red to drop into my 129 to make it a 149 again or put the K321 in my 100.
| Thread Tools | |
| Display Modes | |
