Old 06-11-2015, 10:57 PM
He said, "pull the cover off the air filter and give it a little shot of gas down the carb throat" nothing about carb cleaner....
If you pull the cover off the air filter and give it a little shot of gas down the carb throat will it start? I hate using ether.
Old 06-11-2015, 11:05 PM
bocephus1991's Avatar
Does this engine use any oil? My k301 in my 1200 was so worn it wouldn't start unless you jumped with my truck. Used a quart in 2hrs. If she's badly worn they don't like starting.
Brian
Old 06-12-2015, 09:04 PM
jcrews's Avatar
jcrews jcrews is offline
The engine doesn't use oil.
I pull off the air filter and prime the motor through the carburetor every time I start the motor from a cold start. I have poured gas directly in the carburetor and it doesn't crank. When I spray a quick shot of ether directly in the carburetor it starts. When engine has been running during the day it cranks instantly with no ether. When I stated in earlier posts that I cranked it the same way you were describing I assumed that was a sufficient answer... Sorry
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 06-12-2015, 09:20 PM
jcrews's Avatar
No gas in oil. It cranks fine the rest of the day using it . It just requires that one shot on first start of the day.
Old 06-12-2015, 10:36 PM
jcrews's Avatar
I mentioned in an earlier post I replaced the fuel pump 2 years ago and the old fuel pump did exactly what you said & in drained gas into the oil, cleaned the crankcase really well.
Old 06-12-2015, 10:58 PM
john hall's Avatar
Kind of late to this one but what about the strength of the spark? I'm thinking maybe the spark is a tad weak. I'm thinking starting fluid is more volatile and helps with cranking when it is cold. Once the engine has some heat in it, it cranks better? Id finish the carb and choke checks as suggested first. Can you choke the engine enough to actually flood the plug when trying to crank it? Grasping at straws here
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 06-13-2015, 07:43 AM
I missed that you tried it with gas, sorry. Have you done a compression test? Just thinking it may be a little low and the ether is just enough to get it to fire.
I trust that you have downloaded the service manual. http://www.onlycubcadets.net/forum/s...ead.php?t=4648
Old 06-13-2015, 08:13 AM
budscub's Avatar
budscub budscub is offline
Default Just a thought
This is just a thought I have, but you don't by chance have a bad intake gasket or loose intake manifold. The reason I am thinking this is:
When cranking slow it may allow enough reduction in vacuum to not pull or vaporize the fuel well. With ether it is vaporized from the can. As for using the gasoline if it doesn't vaporize it will not start. Have you tried to crank it using your hand over the carburator? This one is an interesting problem. I kope you figure it out and I am following this one.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 06-13-2015, 08:37 AM
jcrews
I moved this thread to the Kohler engine area, hope you'll get more ideas here.
Old 06-16-2015, 12:55 PM
jcrews's Avatar
I haven't had time to test the plugs yet but I can't flood the spark plugs with the choke. After that 1 small shot of ether it fires instantly and anytime on during the day no ether is needed to crank it. I'm planning on compression check 2 years ago it was pretty strong just have to borrow equipment. I still need to check carburetor & manifold gaskets also. I hope it's not time for new rings but it's looking that way. Thank you for the help
