Old 06-20-2015, 02:33 PM
stanjo58 stanjo58 is offline
Default HDS 2185 Clutch Question
Hello Everyone,
A little back round...I ran this tractor for two years liked it and then the clutch burned up taking out the oil seal. I took the clutch off put in a box and stashed it in my garage....eh somewhere. Can't find the thing now and I can't read the serial number.
Anyway, I ordered the seal and the clutch that serves my memory best. Installed them today. Looks like the right clutch as it lines up with the other pulleys pretty well. The clutch appears to just slide on the shaft with a spacer behind it and a bolt, lock washer and big retaining washer in the front. Clutch slides under a piece of angle and that seems to be it. Best I can tell the angle iron is all that keeps it from spinning. The bolt holes in the back plate of the clutch don't line up with anything that I can tell.
Have I got it right?
Old 06-20-2015, 04:03 PM
Group_44's Avatar
Group_44 Group_44 is offline
You really need to figure out where your tractor falls in the range of serial numbers. There are three different models in the 2185 line, and they use two different PTO clutches depending on the serial number. The one that uses the little angle bracket to keep it from rotating takes a different clutch than the other two that use a hexagonal pin. Here is a link to the Cub Cadet parts page showing that clutch. If you can't read the serial number can you read the model number? It looks like that will also verify which clutch is correct. If you have the correct clutch how you installed it would seem to be right.
http://www.cubcadet.com/webapp/wcs/s...4-A/0040440013
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 06-20-2015, 04:13 PM
Originally Posted by Group_44 View Post
If you have the correct clutch how you installed it appears to be right.
Without any pics in this thread...... how could you know???
Old 06-20-2015, 05:15 PM
I apologize for the lack of pictures. Everything in the diagram is there and seems to be in order. I was just surprised there wasn't more to keep the clutch from moving.
Thanks for the help.
Old 06-20-2015, 05:18 PM
Group_44's Avatar
I was going on the fact that he said he had a small angle keeping the clutch from rotating and accurately described every piece of the mounting hardware. I also qualified the statement by saying he needed to verify the S/N of the tractor to be sure he had the correct clutch. From now on I'll keep my comments to myself and let the experts answer the questions.
1641 w/48" Deck
Old 06-20-2015, 07:34 PM
You don't know how many times I have wanted to say that.
Old 06-20-2015, 07:41 PM
I've gotten to the point that I just sit back and keep quite. Not my tractor, not my problem. I'll let the members figure it out. It's 5:00 O'clock some where.
OK If your PTO looks like this then all that keeps it from rotating is a piece of angle.
The 2185 used 2 different style PTO's as Group44 mentioned. The other 2 are round and have a stud that screws into the front of the engine to stop the PTO from turning. Gotta go now my cocktail is getting warm.
Old 06-21-2015, 12:45 PM
Group_44's Avatar
[quote=Gotta go now my cocktail is getting warm.[/quote]
Don't want to dilute that Chivas with too much ice.
1641 w/48" Deck
Old 06-21-2015, 04:22 PM
Well shoot, didn't mean to cause headaches. Not having the serial number I had to take a chance on my memory for the part which is not usually a great idea. I'm a decent backyard mechanic, just don't see this kind of stuff everyday. The story does have a happy ending as the tractor works fine now.
Thanks for the help and sorry for the hassle.
Stan
Old 06-21-2015, 05:03 PM
CubDieselFan's Avatar
It is no hassle Stan. Keep asking questions.
