#21
![]() It may last a while or get thrown in short order depending on how bad the original hole is. |
#22
Just yesterday I bought a 2166 shaft assembly with all the poly slugs and both end cups off fleabay for $65 delivered.
#23
If the driveline has no rag joint(s) or poly slugs somewhere I would think an all metal set up would send vibrations thru out the tractor. |
#24
Yeah Illl be using a rag joint up front-a quiet line coupler.
#25
Jeff I've always wanted to ask what do you use to do this? Do you have a special tool or machine or chuck it really slow in a lathe? Always wondered
#26
It's a knurling tool made to do that. Most have two small rollers with grooves on the outside of the rollers. The one in the pic is a diamond pattern, some are just straight lines. Takes quite a bit of pressure pushing the two rollers into the part to be knurled. And yes you don't turn the lathe very fast.
#28
Sorry Jeff I don't type very fast
#29
I must "hunt and peck" with two fingers faster than you
#30
I've got two of those pins on order currently. We'll see how well they work when they get here.
| Thread Tools | |
| Display Modes | |
