The brown truck is finally scheduled to arrive tomorrow with my order from XTREME Motorworks. What painting options/technologies would give the best adhesion without having problems of peeling, give a good finish without going exotic. I am just looking for plain old black. What have you guys had the best luck with? Primer, no primer, an initial etching of the parts? Rustoleum, rustoleum red primer?
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
I'd use epoxy primer, then acrylic enamel paint. Shot it with a hvlp paint gun. If you don't have any experience or access to the equipment you could rattle can it. Or take it to a body shop and have them paint it. That's my 2cts. What are you painting exactly?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
you dont mention what your painting so i will assume its steel. start by scuffing it with a red scotch brite pad and then wipe it with degreaser( brake cleaner also works good) spray it with epoxy primer and then top coat with your color of choice. when it come to spray paint ive had good luck with rustoleum epoxy and paint.
If you want durable, Rust-Oleum industrial enamel, Lowes carries it in black and white around $6 a spray can. I made and painted a handrail for my dads house 3-4 years ago. No signs of chipping or rust, handrail is completely outside. I can't remember if I primed it, if so it would have been with a spray can, nothing fancy. It's the best results I've ever gotten from a spray can.
I have 3 sets of torque arms, 1 for the 1772, 1 for the 1572 and 1 for the 1872 and a 3-PT Cat 0 hitch for the 1772. From what Aaron told me,all items are shipped as bare steel.
Post a pic and I can tell you. This pic is the SGT brace.
Sam, I finally got some free time to take a picture. Maybe these are the correct ones. Let me know what you think.
| Thread Tools | |
| Display Modes | |
