Old 07-07-2015, 12:42 AM
Originally Posted by Berwil View Post
I did the bearing upgrade in the top of the column of my O, made a huge difference in steering along with column rebuild. My daughter (less than 2) can steer no problem. It takes a 1-3/8" OD, 3/4" ID flanged bearing if I recall correctly, same as a cub front wheel, I got a cheap one meant for a hand truck.
Mark, I believe Sammac did the thrust bearing upgrade on the spindles to one of his tractors. There is a write up on here somewhere, but I think he had to machine down the bottom of the axle to make room for the bearings on the spindle.
Bill
I didn't know that anyone had done that, though it doesn't surprise meat all.
I've been thinking about doing that for awhile, but that pesky time thing gets in the way A LOT.
Maybe Sam will post up a link.
Old 07-07-2015, 01:22 AM
Berwil's Avatar
Berwil Berwil is offline
This is all I can find, doesn't mention machining the axle, maybe I dreamt that. You'll have to skip through the petty BS, but someone else recently tried it and had good luck.
http://www.onlycubcadets.net/forum/showthread.php?t............
Bill
