Old 07-19-2015, 12:18 AM
bschmittling bschmittling is offline
Didn't do so well today. Got a second and third place finish. The track is a clay track. Progressive pulls have created a gravely consistency to the surface. As a result, you start digging trenches early on. I am thinking about reversing my tires. Does anyone think this will help?
Old 07-19-2015, 12:23 AM
And pull the loose dirt to the center of tire? Bad idea.
Old 07-19-2015, 07:45 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
no, you don't want to do that. you need to find a way to deal with it. try to hook it in better right away, better balance. tire psi, draw bar distance from the center of the rear axle (that's a touchy one), gearing. no matter how long you've been pulling you always get those tracks you struggle on. just have to try to make the best of it
Old 07-24-2015, 12:01 PM
Default Spinout
Watching other drivers, I have noticed that sometimes they spinout early in the pull. The tire I am watching almost stops but the engine is still revving. That means the tire on the other side is spinning. Short of welding the differential, is there any way to prevent this?
Old 07-24-2015, 02:41 PM
austin8214's Avatar
What axle and carrier are you running? It's easy to shim the spider gears tighter but, if you are running the stock axle and carrier I'm not sure I would waste my time doing that. Your other option is to shift your weight to the side that is spinning. Make sure your air pressure is the same on each side too. Make sure you are using a good low pressure gauge to check the pressure too.
Old 07-24-2015, 04:14 PM
My problem is, I have a habit of wanting to look at my tires. This shifts my weight to the tire I am watching and the other side spins. Think I'll practice not watching them or figure out how to watch them both at the same time without shifting my weight.
Old 07-24-2015, 05:34 PM
dvogtvpe's Avatar
you don't want to watch tires. you want to sit square in the seat. if you lean back, lean straight back unless 1 tire is an issue. most people when they lean back tend to transfer weight to the arm they are holding on with.
Old 07-24-2015, 07:52 PM
austin8214's Avatar
Another thing that I believe helps it is to get all of the weight that you can inside of the frame.
Old 07-24-2015, 08:12 PM
dvogtvpe's Avatar
inside and low to the ground
Old 07-24-2015, 08:25 PM
austin8214's Avatar
Agreed I now fill our belly boxes up first and forget about the weight in there.
