Old 07-23-2015, 12:47 PM
timbo2's Avatar
timbo2 timbo2 is offline
If the engine came with bolts I would use bolts. THe gasket itself shouldn't care if it's nuts or bolts.
If you check the service manual it shows some used bolts and some used nuts.
PM me if you need the Command service manual and I can send it to you.
- Tim
Old 07-23-2015, 01:14 PM
jimbob200521's Avatar
Originally Posted by timbo2 View Post
I just re-used the old bolts on my ch22. The manual says get NEW bolts, they looked fine to me but it's up to you. I just threw the nuts in the toolbox.
I seem to remember reading somewhere that the reason they say to use new head bolts when removing the head is because the head bolts are one time use. From what I read, they are designed to "stretch" so it's recommended to replace.
Don't shoot the messenger, just what I remember reading
-Ryan
Old 07-23-2015, 04:25 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Torque to yield bolts, one use only, they do stretch. Some bigger diesels, they give you a gauge to determine if they can be reused. Really the only thing you have to worry about is, if the bolt breaks or gives up and lets a head gasket leak. It is not too big of a deal on these, but you won't want to take a chance on a big engine. A little more work to go through.
Old 07-23-2015, 11:16 PM
Steppingwolf's Avatar
Steppingwolf Steppingwolf is offline
Guys, thank you for the information. So here I am with somewhat of a problem. I have the type of head set with the replacements nut and washers. They are for the engine with studs. My engine as you know uses bolts. I read in the service manual that if a stud is loose that it should be replaced and not reused, just like the bolts. Sooo, doesn't it seem that the studs could be purchased and put in the block in place of the bolts and if measured properly when installing, properly lock tightened, should work for the better? I'm just wondering. Anybody ever heard of someone doing this?
Old 07-24-2015, 12:10 AM
j4c11's Avatar
j4c11 j4c11 is offline
You're stuck on the stud thing for some reason. Not sure how often you plan on removing the heads, but the bolts are $20 on ebay and you should be good for another 500 hours.
Old 07-24-2015, 02:25 AM
That is affirmative, j4c11.
Old 08-01-2015, 10:16 PM
Here is an update, I bought the new head bolts. Been de-carbonizing, polishing pistons and combustion chambers. Thank's for the advise guy's.
Tags
2084 ch20 head gasket
