I am re-doing my Cub 149 and used Magic rattle can Cub Yellow from Tractor Supply on my frame. I absolutely will not use it again. Paint is too soft and takes forever to dry. I bought a can of rust-oleum Gloss Marigold and sprayed my Hydro Pump and Cylinder with it. Went on well and dried fast. Pretty sure it will be a hard finish. Looked a little lighter in color than the Magic paint. Has any one used it on their Tractor? Also saw a Rust-oleum Yellow Eq. Catipaller rattle can spray paint. Any one used this and if so, how does it compare color wise to the Cub Yellow spray can from a Cub Cadet dealer? Sorry for the long post and thanks in advance for your help. Have a great day.
Bob |
I know where you are coming from with the majic brand paint.
In addition, I have found that Rust-Oleum paints are pretty good. However as J-Mech said, Cub Cadet paint is guaranteed to match. I use paint from the Case IH dealer. It's high quality stuff made by Valspar. I buy it buy the gallon and keep a couple spray cans of each color for touch-ups.
I lost track of what I own a long time ago! |
Thanks for the reply's. At $17.00 a can at my local Cub Dealer, Just can't afford it. I am doing a make over and not a restore as everything will not be as it came from the Factory. I envy those that can do a total restore. Beautiful Tractors.
Have a great day. Bob |
http://www.amazon.com/gp/aw/d/B00EFFX7DS?vs=1
Not sure if this matches the old yeller or new? But a good deal on good paint.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
For what it's worth... In my area I have found spray paint at the Cub CADET dealers is in that $17 range, but at the IH dealers it is around $10...
Good luck,
David |
The Valspar paint takes A LONG TIME to dry. Weeks,3-4. I did a 46" deck using the IH white. Great paint though, excellent coverage, doesn't run, and once dried it seems like it will take some abuse.
This is the Hot Set Up.
http://www.lowes.com/pd_636356-678-O...=50404976&pl=1 Cheap and dry's fast, just take a chip and they will match the color. Don't need no stinkin gun, a brush or roller and your good to go.
Sam Mac,
I would never use a brush or roller on my tractor. I'm from Wv. but I have my limits. Don't know if you are joking or not but no problem either way. Have a great day. Bob |
I was just goofing. I tend to have a twisted sense of humor. If it's after 5:00PM all bets are off. ![]() ![]() ![]() ![]() :bigth ink:
Brushes and rollers are for detailed work, a mop is what real men use to paint things!
| Thread Tools | |
| Display Modes | |
