Old 08-27-2015, 06:51 PM
Phil21502 Phil21502 is offline
Default Cub 127 charging issues
I can't get my cub 127 to charge. Had the generator rebuilt and it is getting 13.65 volts from the f terminal on the generator to the battery ground. Ammeter stays on the O. And I have 12.56 volts at the battery. I put a new voltage regulator on too but can't see any sparks from polarizing it. Went over all the grounds I could find and cleaned them. Any ideas? Thanks
Old 08-27-2015, 06:57 PM
Had the generator rebuilt.....I put a new voltage regulator on too
The S/G should be putting out about 14.5 VDC at full throttle.
IF....the V/R is the correct one, and it is wired correctly, make sure that the V/R is properly grounded. There should be zero ohms resistance between the V/R mounting feet and the battery negative terminal.
Old 08-27-2015, 07:03 PM
Can you clarify this? 13.65 to battery ground? F terminal is indeed meant to be grounded but switched if you will by the v/r, not a constant ground. Have you verified that everything is wired correctly? 2 wires on A terminal and 1 wire on F terminal. Wiring has to be correct in order to get that 13.65 volts to the battery. See below link for proper wiring
http://www.onlycubcadets.net/forum/showthread.php?t=35
Old 08-27-2015, 07:38 PM
Yes everything appears to be wired correctly by looking at schematics. I'm at a loss.
Old 08-27-2015, 07:42 PM
I guess it's possibe to that the new voltage regulator is working either? It's from eBay with the gen terminal underneath it.
Old 08-27-2015, 08:03 PM
Oh and is there anyway to measure voltage from the regulator to the battery to see if maybe a wire is broke in the harness somewhere?
Old 08-27-2015, 08:09 PM
That's what's confusing to me. If you have 13.65 at the s/g A terminal then you should have 13.65 at the battery because of the way it's wired. Do you have it at the F terminal? If you do then it sounds like s/g wired wrong internally or maybe it was rebuilt for CW rotation instead of CCW
Old 08-27-2015, 08:34 PM
I have 13.65 volts from the f terminal to the battery ground. I never used the voltmeter from the a terminal to the battery ground.
Old 08-28-2015, 05:33 PM
Well tonight I ran temp wire from the bat terminal on the voltage regulator to the negative side of the ammeter. The ammeter started working and I have 13.54 volts at the battery. Sound like that's the problem? If so is 14 guage wire big enough for this job? Thanks for all the help
Old 08-29-2015, 05:06 PM
Well I just ran the new wire. Went with 12 gauge. Decided to try polarizing again before starting and what do u know I got the spark this time. Fired it up and its charging perfect. Thanks for the help guys.
