Old 10-08-2015, 04:37 PM
Jeremy_K Jeremy_K is offline
Default Can't find quick pins for mounting 450 blower
Can anyone tell me where I can find the quick pins that pin the 450 blower to the frame of my 1211/1810 CC? I can't find them online. Parts houses say they're discontinued. I made a couple of pins but they're cumbersome to use. Thank you
Old 10-08-2015, 05:53 PM
If you are talking about "hair pins" or "R" clips or draw pin retainer clips, Tractor supply has them in various sizes.
Old 10-08-2015, 11:18 PM
According to the diagram in the manual, they look like a pin with a pull ring on one end and a spring loaded ball bearing on the other end. I haven't found anything at tractor supply that looks like them or compares in size. They're referred to as quick pins in the manual. They're just shy of 3/4" diameter. 5/8" is too sloppy.
Old 10-09-2015, 12:43 AM
Have you tried McMaster Carr?
Old 10-09-2015, 01:23 PM
I will try them. Thank you.
Old 10-09-2015, 07:50 PM
Are you looking for # 30 in the picture? 738-0750
Old 10-09-2015, 08:59 PM
This is them.
Old 10-09-2015, 09:17 PM
Looks like they would fall out,prolly why they switched to the ones I show.
Do you have a part #?
Old 10-09-2015, 10:27 PM
My local do it best hardware store has a whole rack of those pins, not sure if they would go big enough though (11/16"?). If you have a hardware with a "big" nuts/bolts aisle they may surprise you.
However... I've had assorted things with those before and it never seems to take too long for that little detent ball to fall out and make the "quick" pins "instant" pins. I usually swap them for something else, even if its a nut and bolt, and I generally prefer loop wire pins. Not sure if they will work for your application or not.
Old 10-09-2015, 10:39 PM
gdheck's Avatar
gdheck gdheck is offline
Here you go.
McMaster Carr
I think I would use a clevis pin with either a cotter pin or hair pin instead though. I don't like how the ball in the quick release pins tend to wear a groove in the parts it holds together sometimes.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
