Old 10-18-2015, 09:38 PM
bschmittling bschmittling is offline
Originally Posted by dvogtvpe View Post
did you put a steel pinion bearing holder in?
No. Do I need to?
The AT101s are pretty thin. Have you tried them at 7 psi.?
Old 10-18-2015, 09:45 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
yes you do.
I've never run those tires. but under pulling theory hard track = hard tire. soft track = soft tire . on a soft track you don't want the point of the tire digging in. you want to spread the tire out more for a larger footprint. hard track you want allot of point , so you raise the pressure to get allot of pressure on the center of the tire
Old 10-20-2015, 12:36 AM
then you probably want to budget in a good carb if you're going with the rest
Surprisingly, it doesn't look like the venturi was bored out at all. Will this carburetor be good enough, or do I need to send it somewhere else for more work? I have no idea what was done on the inside other than a basic rebuild.
Old 10-20-2015, 11:56 AM
austin8214's Avatar
Originally Posted by bschmittling View Post
I ordered a stock appearing, reworked #26 carburetor from Zach Kerber. Surprisingly, it doesn't look like the venturi was bored out at all. Will this carburetor be good enough, or do I need to send it somewhere else for more work? I have no idea what was done on the inside other than a basic rebuild.
Use it as is the idle circuit has been reworked as well as some other things. Boring out the venturi might only hurt torque on the big end of the track.
Old 10-20-2015, 12:03 PM
OK, thanks. Did you ever order that governed carb from Lakota?
Old 10-20-2015, 12:07 PM
austin8214's Avatar
I have it but have not used it yet as, I have not had time to take it to the dyno for tuning yet.
Old 10-23-2015, 01:03 AM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
Do you guys use a PTO dyno? Just wondering because a lot of you guys that have a lot of pulling experience, that I appreciate, talk about dyno runs i was just wondering how you ran those runs. Thank you.
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
Old 10-23-2015, 02:25 AM
austin8214's Avatar
Most have a test stand that the engine bolts to and is hooked up to either the PTO end of the crankshaft or the flywheel. Just depends on the set up.
Old 10-23-2015, 06:19 PM
CumminSHO's Avatar
I appreciate it, thats good information. thank you
Brinly 10" plow
42" deck
Old 10-23-2015, 08:02 PM
dvogtvpe's Avatar
we dyno off the PTO end. I think if we ever did it again we would drive off the flywheel end. I think its hard on cranks when you have a heavy flywheel
