I have the opportunity to buy a super frame with the dual brake setup still on it, the guys not sure what model super its from but I'd say it's from a cyclops judging by the pic. What I want to know is if this frame will work on my 1811 and if not can I atleast use the dual brake setup? Thanks
-Ryan
We need a tumbleweed emoji cuz this thread is like a ghost town, I guess my question was to hard.
You should be able to transfer most of the 1811 parts to the Super frame. Except for the drive shaft, front axle, steering and fenders. Trans linkage is also longer on a Super. Dash tower and hood should be a bolt on.
Thanks Sam.
I own neither machine, but I'll take a swing. Someone will correct me if I'm way off base.
I would think if you have external brakes on you 1811, you should be able to swap the brakes over. I'm sure you will need to do things like shorten the brakes linkages and drill a few holes. Does the super frame have axles? Supers have taller front axles, so if you use your 1811 axle, you will have a "low rider". Using the 1811 rear axle and tires will level it out, but hamper the use of decks and such. Bill |
If you have pics post them and maybe I can give you more info.
Why would the front axle not work and steering not work?
The only difference between the frames is the length, and fender pan height.. So any linkage parts will need to be longer. The frame is lengthened right at the dash tower, so your manual steering linkage should be the same. Can you put the dual brakes on the 1811...... sure. But they aren't bolt on. The pedals won't fit like they do on an SGT because they hit the side panel. (That's where the SGT frame is longer). Also, because of lower mounting fender pan there is issues getting the linkage under the fenders not to interfere with the mower deck. Grab the frame. It's worth having. Even if you tuck it in the corner. |
Supers have a larger front axle and power steering.
| Thread Tools | |
| Display Modes | |
