Old 11-12-2015, 09:27 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Got back to putting parts on today. I know the "correct" police will be all over the lock washers, but as the thread title says, "O face lift" no restoration
Todd...
No possible way this is just a facelift anymore!!
It is an awesome over the top restoration!! quit kidding yourself!
LOOKING AMAZING!! don't worry one second about the correct police! It's your tractor and should be how you want it
Jay
Proud owner of the following:
Old 11-13-2015, 12:49 AM
Thanks for the compliments guys, greatly appreciated.
Originally Posted by jaynjeep View Post
Todd...
Appreciate the compliments Jay, but to me a "restoration" is as was from the factory, no wiggle room on the definition. That's every part, put back and detailed the way the machine left the factory the day it was born...
I know I don't have the means or desire to reproduce such a tractor so that's why I call it a "facelift" rather than a restoration that it's not
I used to hang around a guy who built cars for clients who were sticklers for originality, and saw what it took to build a 100 point "restoration". And after seeing the amount of work that goes into a vehicle to be consider a true restoration there's no way I can consider my stuff in that category.
If for the sake of this discussion I was to enter the Original in a garden tractor show and put it in the restored class. The judges would chew me up and spit me out Because it's not correct. "restored"
Restoration refers to the process of restoring a tractor to its original condition. Neither updating nor modifying are considered part of the restoration process. A restored tractor is one that has had all of its systems and/or parts restored to original condition. Selectively restoring parts or systems is referred to as refurbishing. It does not qualify as restoration.
A tractor that has had its tin work restored to as new condition but has undergone some modifications elsewhere is either a modified or a resto-mod tractor, neither being completely restored nor completely modified. If a tractor has had an engine swap for other than the original model, that tractor has not been restored. Although most of the parts are original, it qualifies as modified rather than restored.
There are many aspects to the process of a tractor restoration. The goal is to return the tractor to its 'original' state
I never use the word restored or take it lightly.
But thanks for your vote of confidence, it is greatly appreciated.
Old 11-13-2015, 09:34 AM
dgrapes59 dgrapes59 is offline
I have done several "facelifts" on some working Cub Cadets..... Or so I thought/called it.... after watching the great job you are doing I guess I just gave mine a shot of Botox!
Thanks for the play by play you are sharing, I have enjoyed following it!
David
Old 11-13-2015, 07:23 PM
Sugarmaker's Avatar
Todd,
A tractor you can be darn proud of!
I cant seem to get anything done lately on tractor related issues. In a slump I guess. Hope things are good in WI.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-13-2015, 07:55 PM
Thanks Dave and Chris
Got some more put together today, plus pulled a dumb move. Must be two people, because one can't be this stupid.
I forgot I needed a good ground for the tail light on the fender pan, so I took it back off and cleaned up a spot on the top of the differential and bottom of the pan. Good.
Then figured while I had the pan off I would drill the holes for the light bracket. Bad. Drilled the darn holes in the wrong location So now I need to blast the pan again, weld the holes shut and drill two new ones in the correct location and re-paint the pan... Boy does that stink
I agree on the lock washers. Nice job.
Old 11-13-2015, 08:40 PM
I hate to tell you this ...
but those brackets that hold the rockshaft on go on the inside of the frame.
BTDT.
Old 11-13-2015, 10:47 PM
jaynjeep's Avatar
OK Todd....
You got me straight on definition of "Restored" and I agree!!
But it's still ALOT nicer than just a Facelift!
Some of my buddies think a restoration is blowing the dust off and rattle canning it!!
Maybe we should call it a restomod or "restification"
Either way... you do great work and I can tell you take pride in it.. That's all that matters!
Have fun and keep the pics coming!!
Jay
Old 11-13-2015, 11:38 PM
BTDT.
S.O.A.B.! Well back to fix that tomorrow...
Should have looked at my before pictures before putting it together. Learn from my mistakes I guess...
Berwil's Avatar
Berwil Berwil is offline
It looks great Todd!
Bummer about the fender pan. The bracket on the lift arm, do you connect anything to it? If so what? I don't have one of those brackets on my O, just curious.
Bill
