Old 11-27-2015, 03:36 PM
yeeter yeeter is offline
Instead of shopping, and with a day off with soccer season over, some time in the shop today.
Junk tractors keep collecting around my shop and so thought I should just put this together to where it runs and drives, then shift to sheet metal work after that. I recon the engine and drive train is next then.
With the harness in and all the dash connections in place, I sprayed the entire back side down with Boeshield. Its a protective film that stays in place pretty well and offers another layer of moisture resistance.
On all the connections I squirted red grease up into the connector housings and on the terminals before pushing them together.
Old 11-27-2015, 03:38 PM
Then put the firewall in.
Old 11-27-2015, 03:40 PM
Then pulled out the engine that had been sitting in the corner for all this time. I had washed it before pulling it, so even though its not too pretty its much better than what it started as (see early pics). It got another wash, brush, scrub, soak, repeat.
Old 11-27-2015, 03:43 PM
The usual crud around the generator stator. And with the valve covers off, I noticed some crud buildup around one of them. This engine is going to be pulled and torn down and inspected so at this point Im just going to throw it together so I know where all the parts are. Then I can clean up and purge all the extra parts, and the shop will be much more workable after that (ya, a dream, but its a good story and Im sticking with it).
Old 11-27-2015, 03:47 PM
Cleaned it up a bit. Cleaned up better than I thought it would. Painted the aluminum with gloss black engine spray can. It might flake, but it looks shiny for now.
Old 11-27-2015, 03:49 PM
I think the screen cover over the flywheel might be upside down, will have to check that in the morning. New gas lines and filter while I am at it. Next step is the tins and then it can go back into the chassis.
Beer oclock
Oh, look at this vane insert that was between the manifold and the carburetor, hadnt seen that before.
Old 11-27-2015, 05:28 PM
ccguy's Avatar
ccguy ccguy is offline
Nice work and progress! You're on a roll now. What again is the purpose of the vane insert? Why do some Kohler 17's have them and other don't?
INTERNATIONAL HARVESTER
- A Great Farm Heritage Comes Home.
1811/682/782/1440/IH #4/IH QA 42"
Old 11-27-2015, 07:59 PM
CC1450's Avatar
CC1450 CC1450 is offline
lookin good from here!
-Mark
1978 1450
1976 1450
Old 11-28-2015, 05:53 AM
twoton twoton is offline
Lookin' good there yeeter, glad to see you're makin' progress.
Old 11-28-2015, 11:12 AM
garrynok's Avatar
garrynok garrynok is offline
Very nice build! I am a fan of the powder coating. When I put my 782 together I had all the sheet metal powder coated. Cost me $80 which I thought was a great deal.
Garry
