Old 11-28-2015, 09:26 PM
I have this tool that's a hole punch on one side and the other side steps the metal in so the 2 pieces of metal sit flush with each other.
Cool.
That tool is now on the list of tools I don't have, but want.
I borrowed these from my friend Dave when I had to patch a set of expansion chambers for my Kawasaki H1
Nice work
Old 11-28-2015, 09:46 PM
That looks like to much work.
Old 11-28-2015, 09:57 PM
I was only doing small areas and since it's was round, warpage was less of a problem.
Plus them were to the point of either patch or throw away ( and I didn't have $700 for another set of chambers )
Good thing it's underneath and can't be easily seen
Old 11-29-2015, 01:37 AM
Lot of work Tim, was it pretty solid to start?
The 56's have a killer interior. So much style, and chrome.
Old 11-29-2015, 11:34 AM
It's not to bad, the quarters are pretty rotted but other than that its solid. There's a ton of chrome and stainless trim on this thing, when we sent it all out to have the chrome redone and the trim polished it cost a little over $15000 to have it all done.
Old 11-30-2015, 06:50 AM
sbauerz28's Avatar
Up close pic of the seam. When it comes time to weld I will start by plug welding the big holes closed and then weld the seam solid, once the seam is welded I will remove the screws and weld the holes shut. It will probably take the better part of a day to weld this solid without warping it.
Looks good Tim. What size holes do you use for plug welds? The reason I ask is because I spent Thursday afternoon and Friday making a nice sheetmetal closeout panel for my firewall and it warped bad when I welded it. I then spent Saturday cutting it off to make another panel. I used 5/16 holes and I think they caused to much heat when I welded it. Think I'm going to try 3/16 or 1/4 holes next time.
This is what it looked like before and you can see how bad it looked after I welded it.
Old 11-30-2015, 11:46 AM
The holes are 5/16 . welding sheet metal is a pain and it always seems like everybody want to turn the welder down so there's less heat but the problem with that is it takes longer for the weld to burn in good so it actually creates more heat, I always run the welder hot so I get a quicker burn in. When I weld sheet metal I only do a 1 second spot weld then move and I always try to keep about 2ft between welds so the metal doesn't get to hot and warp. When I weld the long seam on the quarter I will spot weld it on one end then move to the other end and then go to the middle and I keep jumping around like that which allows the metal time to cool.
Old 12-05-2015, 11:28 AM
Now that the right side is fitted and ready to weld I'm getting the left side fitted, I just got done cutting off the old skin.
Old 12-05-2015, 03:39 PM
Started welding and hour ago, going smooth so far.
