Old 11-29-2015, 06:39 PM
Workinprogress Workinprogress is offline
Default 1512 Rear Cover Torque?
Pulled the 1512 into the garage for a once over before putting the snowplow on for the winter. Wanted to change transmission fluid and grease the machine up. Noticed the rear axle end seals starting to leak, carrier seals little leak and one of the rubber grommets on the gas tank leaking diesel. Pulled everything apart, made a list of parts and placed an order online. Looked through my cub cadet manual and couldn't find torque specs for the rear cover bolts.
Found the basic chart in the front of the book showing 21 ft lbs for a 3/8 inch bolt. Any thoughts?
Also any thoughts how long the axles end seals last? I looked over my records and it seems I replaced them 10 years /500 hrs ago. Is that good or bad?
Thanks
Old 11-29-2015, 07:02 PM
Just use a 3/8 ratchet and tighten them until there tight, torqueing them isn't necessary.
Old 12-10-2015, 08:23 PM
As suspected when I pulled the axle tube.
Old 12-10-2015, 08:27 PM
While the fluid looked good in the rear end. The axle tubes looked bad. Return holes already drilled in housing!
Old 12-11-2015, 09:57 AM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
30 foot-pounds will be sufficient for the axle tubes.
Old 12-11-2015, 11:55 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
The rear PTO installation instructions take some rear cover bolts off, remove the hitch and then you have to re-attach while tightening the bolts to 30 Ft/lbs. I would think they would all be the same torque.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
