Old 12-06-2015, 05:47 PM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
Default 1450 hitch options, 3 point, sleeve or ?
Is one type of hitch better for the 1450 than the other? I'm seriously thinking about putting a hitch on my 1450 but am in a quandary as to which type to pursue.
Steve
Steve
1450
QA42A Thrower
44A Mower
Old 12-06-2015, 05:58 PM
I make various parts including a heavy duty sleeve hitch adapter.
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Since each one is custom made for the purchaser, I can make it however you want.
Jeff
Old 12-06-2015, 06:27 PM
Nightow1 Nightow1 is offline
This would depend on what you have or are looking to get for attachments.
Old 12-06-2015, 06:33 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
What he said. Cat 0 is going to take alot more punishment. Also allows for alot more adjustment. CC 3pt is ok for a plow and junk...
1- 1200 in pieces
1- 1864 in pieces
Old 12-06-2015, 08:26 PM
johncub7172's Avatar
Many IH implements and allied as well, were designed for use on your 1450 with the IH lift components, usually called "3-point lift. You need this piece in order to use the part JeffinPA pictured for you.
Extreme Motorworks now makes a CAT 0 for the IH Quiet Line.
Old 12-06-2015, 08:53 PM
I would do the cat 0 3pt, that way you can still use brinly equipment.
Old 12-07-2015, 05:28 AM
twoton twoton is offline
I'd stick with a stock 3 point and build one of these to grade your driveway;
http://www.onlycubcadets.net/forum/s...412#post189412
