Old 12-16-2015, 08:21 PM
Default What is one thing you wish your cub had but doesn't?
Hypothetical question of course, since I've got nothing better to do with my Cub as it sits in the garage with no growing grass to cut or snow falling to push.
What is one thing you wish your cub could have but doesn't?
If you've got more than one, pick one. Just play along for the sake of winter doldrums.
I'll start. I'm going to say power angle for my snow blade. I don't mind the armstrong lift (since the E lift is way long gone) but not having to get off the tractor to change the blade angle would be great.
Old 12-16-2015, 08:27 PM
twoton twoton is offline
Diesel power.
Old 12-16-2015, 08:42 PM
id have to go with power angle also, id rather have power angle than power lift.
Old 12-16-2015, 09:13 PM
Jumper Jumper is offline
Cab heater! Burrrrrrrrr
Old 12-16-2015, 09:32 PM
john hall's Avatar
More ground clearance for the front gauge wheels on the 60" Haban under the 2072. They hit the gravel drive pretty hard between my house and dad's.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-16-2015, 09:34 PM
john hall's Avatar
I wish there was a way to lock the deck in the raised position on my 982 so I could use the 3pt hitch. I used to run a small Deere compact tractor that had that feature by installing some lock pins.
2072 w/60" Haban
Old 12-16-2015, 09:38 PM
bbrown8's Avatar
bbrown8 bbrown8 is offline
Hyrdro Lift. I think I'm going to have a beefy right arm after this winter. Then again winter might not come and I won't complain.
-Buster
1984 CCC 680 Hydro. Attachments: 44C Mower and QA36A Snow Thrower.
Old 12-16-2015, 09:53 PM
cadzag72 cadzag72 is offline
Four wheel drive.
Ian
Old 12-16-2015, 09:59 PM
More traction when I am stuck in the snow spinning my tires with chains. I've tried to remedy the problem by going on two diets since one diet didn't give me enough to eat, but it's not working fast enough.
1811woody's Avatar
Originally Posted by cadzag72 View Post
Four wheel drive.
I was going to say a locking differential but 4 wheel drive would be a better wish
