Old 12-21-2015, 11:28 AM
Old Skool Old Skool is offline
Default 1872 rear end
When replacing bolts that hold the axel tube to the rear end do you use red locktite like it came from the factory?
Old 12-21-2015, 01:45 PM
CubDieselFan's Avatar
I would use green or blue. but not red.
Old 12-21-2015, 02:03 PM
I use silicone and lock washers.
Old 12-21-2015, 03:54 PM
That's close to what I use too. Instead of silicone I use anaerobic sealant, Loctite brand and then of course the lock washers. I use the anaerobic sealant because it sets up harder so it has more of a loctite effect.
Old 12-21-2015, 04:53 PM
Thanks for the reply. J- Mech, I can't even pronounce the stuff you use!! But I will check at Napa for some to use on this project. I'm just hoping my son can get the 3 bolts out tonight, he has more experience at that than I do. " I really don't want to screw this up!" I think I have read somewhere while I have this apart that I can drill a hole so oil will drain better. Can someone refresh my memory on this. Thanks again guys!
Old 12-21-2015, 05:25 PM
Try this thread.
http://www.onlycubcadets.net/forum/s...ad.php?t=24352
