Old 01-08-2016, 11:42 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Default Deck Stop Froze Up
My 1641 quit running yesterday, I hooked up another fuel source and it ran fine so I'm replacing the fuel lines and rubber grommets in the tank. While i've got it apart I would like to do something about the deck stop. It's froze up tight, I've had a big wrench on the back and got no movement at all. I haven't tried heat because the gas line is close but I could while I'm replacing it. If nothing works should I cut the bolt that goes through the arm (short piece) or the thread rod? I've soaked it several times in PB Blaster.
Cannon
Old 01-08-2016, 01:46 PM
They are notorious for bending and breaking the rod that extends out the back of the tractor. Also the threaded end has a smaller diameter left hand thread nut that is screwed onto the end and is loc-tited in and it's a PITA to get off without twisting the end off of the rod. My guess is you will need some heat.
Looking at your pic I think yours has a slight bend in it.
Old 01-08-2016, 02:20 PM
Cannon51's Avatar
Thanks Sam. I tried my old propane cylinder torch and got nowhere. I been meaning to get a new one that uses Mapp fuel, maybe that would help. I thought about cutting the clevis pin (Cub Cadet 711-3317) but looks like it's NLA. Looks like a business opportunity Sam. You should have about 100 of those made up. Just kiddn.
Cannon
Old 01-08-2016, 02:25 PM
I may have one of those pins laying around, have to check.
Old 01-09-2016, 03:29 PM
Cannon51's Avatar
Today I cleaned the fuel tank and replaced the fuel lines and grommets. One petcock was totally blocked with trash and the other was partially blocked. I soaked them in Diesel fuel and blew them out. I tried my little propane torch again and this time it caught fire at the adjustment knob. Time to retire it so tonight I plan to pick up this http://www.lowes.com/pd_387416-743-T...uctId=50126389 . I hope it makes more heat than my old one.
Cannon
Old 01-09-2016, 05:24 PM
Oxy Acetylene torch. A must have.
Old 01-10-2016, 03:54 PM
Cannon
I do have one of those clevis parts. Also have a rod out of a super that has about 1/2 of the threads broken off so you could cut it to the length you need and thread it. Yours for $10.00 plus shipping.
Old 01-10-2016, 04:39 PM
Cannon51's Avatar
Just came in from the garage, I got it broke loose. This morning before church I went out and took a box end wrench and cranked about 90 degrees of pressure on the rod and heated the pin up . I could not get the pin red but the washer beside it was. I did that two times and nothing moved, I figured I would have to cut it out. After church and lunch I went out to remove the clamp and there was no pressure on the wrench. It must have freed up as it cooled. I soaked it down with PB blaster and started cranking the rod with the wrench until it freed up. I ran it 3 or 4 cycles from the stop screw to the end of the threads until I could go all the way with out the wrench. I considered trying to remove the LH screw but decided to leave well enough alone. The rod is a little bent, It wobbles about 1/4 in when turned. I need to replace the wire cover on the harness above the pin. I melted a little of it. Thanks Sam, hold on to that pin someone will need it.
Cannon
Old 01-10-2016, 05:33 PM
You could say going to church helped,
sure as heck don't hurt,
but I don't think it would work twice
