Old 01-12-2016, 07:37 AM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Default To float or not to float
Good morning all. I want to pick up a plow and start sod busting. I understand you can use slotted lift straps so the plow can float, or drilled straps to be able to apply downward pressure. Any advice as to which is better or if there are different applications to use either type of straps? Thanks!
Old 01-12-2016, 08:57 AM
If your running a moldboard plow you need the float lift straps or you can use the float on the tractors lift handle if you adjust the straps to the proper height so the plow doesn't go too far in the ground.
Old 01-12-2016, 09:27 AM
Jeff122's Avatar
Thanks Tim. I have a hydraulic lift on my 122. So I guess I need the slotted straps.
Old 01-12-2016, 09:36 AM
Hyd lifts also float, that is unless you have the lockout tab installed.
Just use the deck adjuster knob to control the depth..
They handle a plow well, but once you spin a wheel and drop down a little all bets are off regardless whether you have a GD or hydro.
Old 01-12-2016, 10:03 AM
Jeff122's Avatar
When I got my tractor, there was no mower deck or any hardware related to a deck. So I'm not sure what you mean about a lock out. I fabricated a linkage to raise and lower my snow plow, but of course that floats because of the lift chain. I appreciate all your input, guys. The more I learn, the better.
Old 01-12-2016, 12:06 PM
Part #9 in the parts look-up
Old 01-12-2016, 12:07 PM
Look at the parts blow up. It shows in there. Only way to get down pressure from the hydraulics. t eliminates the float. float lockout pin. Part #9
http://www.cubcadet.com/webapp/wcs/s...0-A/0028100031
Old 01-12-2016, 12:25 PM
Jeff122's Avatar
Thank you very much. Is that pin generally in for a mower deck? It used to have a deck before I got it. If I want it to float, I take that pin out?
Old 01-12-2016, 05:15 PM
Merk Merk is offline
You will want the floating style lift straps for anything you put on the back of your Cub Cadet.
I do not use the lock out pin when I have the snow blade or mower on. They need to be able to float unless you have flat surface. Good way to break pins in the lift system(been there-done that) and they can be a pain to change.
Project Uncle Dick
Cub Cadet 70
Old 01-12-2016, 05:22 PM
I'd say chances are you do not have one in there. Pop the tunnel cover off and take a look. Should be obvious as to how the system works once you take a look see.
