Old 01-12-2016, 06:47 PM
Probably would be best if we knew what model the tractor is before we explain how to make the impalement lift float or not.
Not sure how many tractors the OP has but it looks to me like he has a 1X2/3 with a hydraulic lift.
Old 01-12-2016, 07:08 PM
Plow depth is controlled by the pitch of the plow, not by stopping the hitch. The plow will suck itself in and go to the depth that it is set to on the plow. Has nothing to do with the hitch. That's what the adjustment to roll the pitch of the plow is for. The plow and tractor should float independent to follow the contour of the ground.
Old 01-12-2016, 08:44 PM
You will want the floating style lift straps for anything you put on the back of your Cub Cadet.
I do not use the lock out pin when I have the snow blade or mower on. They need to be able to float unless you have flat surface. Good way to break pins in the lift system(been there-done that) and they can be a pain to change.
Doesn't one need it to float in case of hooking a rock/root?
Old 01-12-2016, 10:27 PM
I think Dale thought he was talking about a front blade, not a moldboard plow.
Old 01-12-2016, 10:37 PM
Merk Merk is offline
I do not use a lock out on any rear mounted implement, front blade and mower deck.
No one has a totally flat surface.
Project Uncle Dick
Cub Cadet 70
Old 01-12-2016, 10:39 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Thank you to all who gave advice. I think I have a pretty good handle on this. I found the parts I need. I'm not one to force things or venture ahead without info from guys like you. I will post pics when it all comes together. Thank you all!
Old 01-12-2016, 10:58 PM
I agree with you. I just didn't know if you caught that the OP was talking about a moldboard plow since you brought up mower decks and front blades. I don't ever use anything but float either. Like you said, good way to tear stuff up.
Old 01-13-2016, 12:35 AM
I'd say chances are you do not have one in there. Pop the tunnel cover off and take a look. Should be obvious as to how the system works once you take a look see.
OP has a 122 and there is no tunnel cover to take off...
Old 01-13-2016, 09:02 PM
Oops...sorry guys. Should have read better before posting. I also use float for any implement.
