Old 01-23-2016, 07:23 PM
twoton twoton is offline
Grade 5 bolt. Run it!
Old 01-23-2016, 07:24 PM
If you bought it new I suggest that you have a chat with the seller. If not then call Bercomac. Otherwise stick a grade 5 or grade 8 bolt in the hole and sprinkle some holy water on it and go get your snow moved. Don't want to sound like an A Hole but I'm at a loss for an answer. As long as your not feeding it rocks or frozen chunks of Ice a blower should not be spitting out shear bolts. They are meant to break when the system has been over stressed. Sorry but something is wrong and I can't diagnose it from here.
Old 01-23-2016, 07:29 PM
seanmmcc seanmmcc is offline
i bought it used. it had never been used previously. i put more wear on it today than it ever had. not hitting anything but snow. its wet but not too heavy. grade 5 seems like the right next step. here is the manual if anyone wants to see if I am missing something. Swear i did read it....
https://drive.google.com/file/d/0ByH...ew?usp=sharing
it is a class 8.8 shear bolt by the markings on the top.
Old 01-23-2016, 07:40 PM
gt383mag's Avatar
gt383mag gt383mag is offline
im with Sam get a heavier bolt
Old 01-23-2016, 07:48 PM
athomas's Avatar
athomas athomas is offline
I would go with the eat less snow and a bolt might get you by, thats a lot of load if your moving to fast something got to stall or break ,chew it up slow or try a half width cut.
Old 01-23-2016, 07:52 PM
8.8 as far as I know is a metric marking a Grade 8 bolt would have 6 lines on the top of the head.
Old 01-23-2016, 09:21 PM
ivel03 ivel03 is offline
2 things - according to the manual it looks like it calls for shear pins with nylon lock nuts and as far as i can tell everything is std size, not metric. Looking here a grade 8.8 metric bolt is close to grade 5:
https://www.boltdepot.com/fastener-i...ade-chart.aspx
Make sure the shear bolt size is correct; i've seen small ones that slop around break easily and it won't have the strength needed because it's a smaller bolt.
Hope this helps.
Old 01-23-2016, 09:28 PM
john hall's Avatar
Take a look at these sites/pages. If I am converting things correctly, you are already running something stronger than a Grade 5 bolt. So are you using metric bolts? Wonder if you could try a Grade 5 in a standard thread--6mm and 1/4 are close, 8mm and 5/16, doubt you have anything bigger than that.
I'm just wondering if you got some crappy bolts. Dangerous game when you start substituting shear bolts with anything other than OEM--do so at your own risk.
https://www.boltdepot.com/fastener-i...ade-Chart.aspx
http://www.mcmaster.com/#hex-head-cap-screws/=10tbaeb
https://www.fastenal.com/en/76/metri...specifications
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-23-2016, 09:30 PM
john hall's Avatar
Hope this helps.
You got it posted before me, I closed OCC tab by mistake!
2072 w/60" Haban
Old 01-23-2016, 10:06 PM
i had 2 bags of the shear pins. one came with the blower the other was a pack i ordered earlier this year. Both bags break. The bolts are all marked with a SM and underneath of that 8.8
Is this correct?
8.8 metric is 116,000 psi and grade 5 sae is 120,000 psi?
thanks again for all the help guys. I have still managed to blow a mtn of snow. we got 25", I can hopefully get the neighbors drives. I started with 20 shear bolts, I have 9 left.
Sean
