|  | Thread Tools | Display Modes |
			#21
			I let all of my stuff warm up before I put a load on it. I'm old school and I'm not changing what has worked for me all my life. My big Cat diesels always went 20,000 hours before overhaul and even at that most of the parts were still good to re-use. I think this article is BS.
				__________________ 2264 with 54 GT deck 1641 AKA Black Jack with a 402-E Haban Sickle bar mower JD317 dump truck BX2670 with FEL |
			#22
|   Quote:
 I warm up the car for 10-15 minutes every morning. |
			#23
|   Quote:
				__________________ -Buster 1984 CCC 680 Hydro. Attachments: 44C Mower and QA36A Snow Thrower. |
			#24
			Yes, engines idle faster to warm them up.... and because to run in the cold they have to dump a lot of fuel down their throat... little extra RPM helps burn the fuel and warm it up.  All engines that are electronic controlled do.  Incidentally, so did the old carbureted engines.  The choke had a cam that opened the throttle plates up to raise the RPM at idle.  This is nothing new guys.  Surely you guys are older than 30 and have to remember pumping the gas to start....  On another note, you may also notice that on most all cars since about, oh, 1996-1999 somewhere in there, it will not let the trans shift into overdrive until a certain trans temp is reached. |
			#25
|   Quote:
			#26
			#27
			Ha,LOL, I remember pushing a peddle on the floor to engage the  starter and being able to hand crank it if the battery was dead. Don't know if I should admit that  Air was dirty and sex was clean, phones had a rotary dial and had party lines of @ least 4 families. you picked it up and listened a minute to see if it was already in use before you dialed. Sometimes us kids listened longer to catch up on the gossip but got our hinneys paddled good if caught!   |
			#28
			First car I drove about 20 years ago was a Skoda Octavia, even that I just turned the key and it started    |
			#29
			Pure EPA or CARB crap! This is what this article is! Almost all machinery were I work (Port of Montréal) Idle 24/7 a week! Some got so many hours on the counter you wouldn't believe it!  Since we normally get serious artic cold weather here (Not this year thank you El Nino) I have block heater on my 2 truck and one of them is a Diesel, I always let them idle at least 15 minutes and both use synthetic oil. I did 400K with a VW golf diesel before I sell it to a young boy who did 200 more with it so like a good cook I don't change a working recipe....Those green pot smoker can kiss my A$$....
				__________________ Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
			#30
			I had a car that you had to pull the choke and do the tap dance with the pedal to start it.
				__________________ Up to 533 and counting... I give up updating my profile! |
| Thread Tools | |
| Display Modes | |
