Old 03-03-2016, 11:36 AM
samckitt samckitt is offline
Default 3 pt Kubota arms work on 1782?
Saw this for sale near me & wondering if anyone knows if it will work on a Cadet 1782. Looks like my tractor came with it but it's missing the arms. Wondering if this would work.
Old 03-03-2016, 03:02 PM
Rear on mine looks like:
Hard to tell but the lower pins are there, I only need the arms, all of them, top & bottom. So I would just remove the lower arms from the shaft pictured above & use them along with the above pictured upper bar.
Old 03-03-2016, 03:06 PM
You are missing the rockshaft. On both your tractor, and in the Kubota parts. The bar in the Kubota parts is a lower shaft, not an upper. The arms might work, but your going to have to make the rockshaft, or buy one.
You know you can buy the correct arms from xtrememotorwork.com right?
Old 03-03-2016, 03:39 PM
Rockshaft...... this?
This is less $ than the reman parts.
Old 03-03-2016, 04:48 PM
cub123's Avatar
cub123 cub123 is offline
As Sam said, they could be made to work with enough fab work. Two issues I see to overcome are the arms don't have enough bend in them to clear the wheels and for the sway blocks to work, plus it's hard to say if they are the right length. 2nd, the links don't have any float like the stock ones.
Old 03-03-2016, 05:32 PM
Anyone have dimensions of the Super's lower lift arms?
These are:
Lower Lift Arm
Center to center of Hole - 20.5"
Overall Length - 23"
Offset -4”
Old 03-03-2016, 05:46 PM
I could not see the rockshaft in the first pic you posted.
Carry on.
