Old 03-14-2016, 09:01 AM
If the pump is run off the PTO, then the PTO has to be ON to RUN the PUMP!!
Period!
The pump at idle, probably don't offer enough of a load to stop the PTO from the residual spinning when in the OFF position
like it does when a deck is installed
Are you sure the PTO is properly adjusted?
Old 03-14-2016, 09:40 AM
Young Cub
Guest
Posts: n/a
Duh! OK LETS GET THIS STRAIGHT THE PTO IS ON WHEN I TRY TO LIFT THE ARMS!
Old 03-14-2016, 09:44 AM
Young Cub
Guest
Posts: n/a
http://www.onlycubcadets.net/forum/a...1&d=1457963030
Old 03-14-2016, 09:45 AM
Young Cub
Guest
Posts: n/a
http://www.onlycubcadets.net/forum/a...1&d=1457963118
Old 03-14-2016, 09:46 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Good simple reading for the OP :http://www.tractorsupply.com/know-ho...-for-beginners
Gilles.
1963 100 (red)/in storage
Old 03-14-2016, 09:48 AM
Young Cub
Guest
Posts: n/a
http://www.onlycubcadets.net/forum/a...1&d=1457963266
Old 03-14-2016, 09:53 AM
Young Cub
Guest
Posts: n/a
http://www.onlycubcadets.net/forum/a...1&d=1457963583
Old 03-14-2016, 10:10 AM
OK Bud, I'm done!
Old 03-14-2016, 10:34 AM
cubs-n-bxrs's Avatar
Did this loader function when you purchased it or did it not work? If it worked what if anything lead to it not functioning. Did you perform any work on it which may have caused it to not work anymore? Just wondering not trying to bash you.
Old 03-14-2016, 10:38 AM
Young Cub
Guest
Posts: n/a
Ok wow! The arrow shows the pump shaft is spinning in the right direction yet i disconnected the OUT hose from the pump and turned it the way the arrow shows... Nothing. I turned the other way and it pumps out so... Someone must have changed the direction of the pump for it to spin the correct way according to the arrow yet not pump out unless spun the other direction. Ok... Problem found! Finally! So how can i change the pump direction back to original?
